Bags are for groceries :P
Always had shit static... considered a cup kit but meh id rather spend 4k on a jz halfcut for the 14
Got a commonwhore for dailying and station duties. This is just for everything else and wouldnt want to ruin it with sloppy bags... nothing worse than seeing some mexican thing jacked up driving along.
We try.. lol. Most of those cars are faaaast apart from a few of us P platers. See my mates red v35 in the middle with GTR front? he just spent 20k on that paint and body kit.. too much money
miners have too much money.. they should give me some of it
Congrats on the purchase Tony, they are indeed a great looking car and rare for that matter. De badging is a great idea, i get people snapping necks to look at the front grille.. then realise it's emblemless haha.
I notice you have one of those underbody reverse lights is it?
Congrats on the purchase Tony, they are indeed a great looking car and rare for that matter. De badging is a great idea, i get people snapping necks to look at the front grille.. then realise it's emblemless haha. I notice you have one of those underbody reverse lights is it?
Thanks mate. The car is actully more well travelled than I am, this was imported from Japan to Britan to Australia where i am the first registered owner. This is why I had the underbody fog lights cause the Brits have such horrible weather. Thankfully it was easy enough to remove as it looked like a big red pimple on it's arse, although now my high mount stop light is now not actually connected at all :whistling:
Actually, how are other peoples front number plates attached to their cars? Mine had a massive plastic section for the brit plates, and now the current plate does not hid the old srew holes as seen in the front pic here. Any thoughts on how to fix this? Can I get another plastic section to attach the plate, or is cutting them off my only option?
Yeah good question it's the same sort of thing at the back with the two hanging hooks don't suit Australian no. Plates. I never bothered to take them off - a few people told me to remove them and just bolt the plates to the bar.. But I worried about scratching the bar. Also removing the back rack the plates mount on would leave a big hole. Really interested what people have used for this. I was contemplating shopping around this week for something.
Edited by ELFGT350
nice, that's a good upgrade. Wrong badge though.
The Jap owner put Infiniti badges on it for some reason. Everything inside says nissan, engine says PV36 ^_^
Just trying to find a different grill that will fit it, having trouble finding parts for a 2008. Lots of confusion online over it being the same as a G35 or a G37. Hoping to find a new grill & sports lip, plus I need to find somewhere to tint the tail lights. Anybody know where to go? I've seen pre cut tint on eBay but haven't tried it.
Loving it at the moment, but noticing it chugging every now and then, maybe from a tank of BP 95? I can't hear the engine from inside the car so I don't notice the gear change as much as I did in the R33, the chug has a similar feel to changing gears (auto) but over & over quickly. Drove it from Syd to Adel so maybe it needs a service.
The all jap computer is a little annoying, english manuals have helped but I wish I could disable Navi all together, esp seeing as I can't replace the cdplayer/navi without stuffing everything up. Been experimenting with a 7" Android tab and a Galaxy S3 as carputer replacement. To many adapters & wires though, I need a old Galaxy Tab P1000 as that has RCA out. Newer android's use MHL, so have to go micro usb > hdmi > rca.
Have HEAPS of Galaxy S3's lying about in pieces though, so trying to slave touch from the default screen but haven't had any luck. I think i'd have more luck with a specific tab as screen with a i/o that'l work.
Missing the R33 turbo as well, luckily it hasn't sold yet so I still drive it sometimes ;)
Edited by awsam
    • The average previous owner for these cars were basically S-chassis owners in the US. Teenagers or teenager-adjacent. I often tell people that neglect is easier to fix than something that was actively "repaired" by previous owners.
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
