The person I'm hanging to meet... RedGTST. Why... I wish to see if he is slightly twisted/mental in person or not.
SHYGRL were you on a cruise last week with a group of VL's?
sure was me! was good to see another skyline there lol
and chamaine i'll be at villis can i please purchase a dvd :P
  • Replies 170
Posted Images
ive met a few people from here but i dont really head out to cruises much anymore so i dont really know any of the newbies
id like to meet everyone sometime but not all at the same time! ive got a crap memory
nothin but love people.
id like to meet anyone i havent met, which is quite a few, but if i had to single out anyone, id say:
andrew(andrewjzx100), we have similar sense of humor and would probably get along well
nisskid, same as andrew.
damo, he seems to know where im coming from, so id say we would get along in person.
craig, hes chilled out and makes me laugh on here.
ryan, most the reasons above, but we also get along on msn.
flick, coz shes nice as...
people i know:
ive known Sam(Sambo33) for a few years, been on countless drives with him, always a good time when were together(strictly non-gay).
ive met Ben(dohmar), hes cool and pretty funny.
ive met Sled, although he probably doesnt remember me. hes a big dude, id like to stay on his good side.. :P , hes nice as though, id think about taking him to dinner.
i may have met others, but i cant remember.
Edited by ted180
ahhh yes, me too for the same reason.....I think you'll find that he's a bit eccentric but he'd be OK in conversation as long as he takes his medication.
I think he's bi-polar and was obviously on a high last week, which explains why we haven't heard from him this week.
Also met Sled, top guy.. let some slightly drunk chick he had only met that night sit on his bike :down:
Cant find the photo of that one though!
Hahaha, there's some video on youtube somewhere from madaz's phone of that night........nightcrawler doing a burnout in the carpark and some members wanting to prostitue themselves to by a bike, lol
haha, lol.......I remember you teddy boy........you seem like a cool dude in person
Not sure if you have been following my thread in the mods section Joel, but Chris (REdgtst) and his alter-ego's miny_minor and max_iman_power have been banned for life :down:
Muahahahahahahahaha, mess with mods and see where it gets you :P
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
