Which Stroker Kit
177 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 168
Posted Images
Oh I suppose I could have posted a dyno plot of an R34 GTR with stock turbos vs the same car running an RB30DET with a T04Z:
Overlay Paul's dynograph in Twoogle too, that would be interesting.
Bare in mind Dirt Garage's car was built to basically set records, the R34 was put together to be an awesome street friendly one- more about drivability and general accessible grunt. A better comparison would probably be one of a RIPS built street/drag car running an RB30DET with a GT4202R on it - here is a comparison of each of their pump gas tunes.
(edit: I had the RB30DET T04Z overlayed initially but it looked like a lower powered big block V8 compared with a RB26 so it wasn't really a logical comparison)
Edited by Lithium
How do you drive the car (drag, street, circuit, etc.) and how often?
All of the above. It's just started to see some circuit action but have also had it down the drags (just the once on shitty old tyres). It's built as a track day car and am planning on doing more events / track days in the near future. It certainly won't do a 9 and I would say at a push with better tyres etc it may, just may crack an 11.0.
I drive it everyday I can but I work offshore and overseas so probably do max 5000kms per year in it. The response is awesome and pulls like a train (Ant Scali's technical term) to 8000rpm. Feels like it's got a lot more than 522hp now and as I write this planning to get some more tuning done as soon as I get home.
I guess whether to rebuilt with a stroker or not is a generally a personal preference in how you want your GTR to deliver its power/torque.
It is easy to see why people are looking at RB30 blocks when it comes to a rebuild, results speak for themselves, so does the price of the block. I am not sure about what needs to be done to make it fit into a 4WD GTR (my guess is a lot), but would be a good comparison pricewise. Full RB26 build to handle 10000rpm vs a built RB30. Maybe I have missed the point of the thread?
Anyway, I would rebuild my RB26 to handle mad rpm, but, considering the point of this thread I would go the JUN 2771cc to stay true to some sort of Nissan Motorsport heritage (the GT cars in Japan are 2771cc I believe).
Mike
$12k for a standard rebuilt bottom end RB30..no thanks.
I don't know where you got that info from, our forged shortblocks that hold over 1000hp arn't even that expensive.
Our rebuilt stock internal bottom ends start at $4000.
http://www.ripsracing.com/products.html
It would be nice if you could get your facts right before you post
Rob
Rob
Hey Rob, Just wanna say nice work on all your cars, you are by far the best fabricator ive seen.
Should start trading on SAU, im sure you would get alot of business once people see your threads on the UK based forum eg Black r34 gtr and black drag gtr.
That build thread kept me entertained for ages.
+1 ... All the work I have seen come from your shop is absolutely stunning, not to mention I have watched some pretty astounding videos where some of the cars you built are at the drag strip. Props my friend, props!
-Allen
I got in contact with Rob From RIPS today and basically for a fully built turn key RB30/RB26 good for 850+whp what I'm looking at is in the area of $40,000 plus. This kit is basically a turn key kit with everything and I mean everything included. I was adding things up for the total build and its actually more, plus you gotta factor in all the time and extra labor when it come to building a whole car like that. So looks like I know which route I'm going.
I've just decided I'm gonna put the car down for a while and just do the entire build at once. I better start working more hours and saving more money lol! :ninja:
I've just decided I'm gonna put the car down for a while and just do the entire build at once. I better start working more hours and saving more money lol! :D
Sorry it might be that my brain is on holiday today - but I'm not quite sure what you mean by you have decided. Does this mean you are going to do RB30? And if so you will soon, or will wait for a while first?
+1 on the list :D
+1 on the list :P
Most people don't realise how much is involved in doing a high power re-power properly.
When you build a real good bottom end with big oil pump, big sump, good quality front damper, balancing etc, water pump, cam belt etc etc, then buy a brand new head and get world class porting and fill the head with tomei components then use good studs, good gaskets and cover the 3 or 4 days labour it takes to properly blueprint and assemble a complete long motor your up to nzd30-32k for a long motor easy as.
Then you start adding ex manifold, turbo, dump pipe, oil and water lines, air intake, wastegate, screamer, gaskets etc, intake plenim, throttle body, injectors, fuel rail, fpr, rocker covers and other covers with custom paint etc and you can soon see how it all adds up.
From what I have been told, its very common for a UK built 1000hp capable motor without all the extras to be 25k pounds at least and the top guys there are only running similar mph in their pro GTRs as we have run in our heavier street car with street tyres so we give very good value for money.
basicly, it soon adds up to alot more than most think when they start there "1000hp" build.
Rob
Rob
What percentage of the cost would you apply to the head versus the bottom end Rob?
And why would you go for a brand new head?
Fark that sounds horny
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
