Steven Jones Nissan Skyline R35 Gtr Is The New Leader Of Quit Targa West Competition Modern Class.
A cut and paste from the Targa West web site
Steven Jones takes the lead...
Perth young gun Steven Jones (Nissan Skyline GTR) is the new leader of QUIT Targa West Competition Modern class overtaking Kevin Weeks (Lamborghini Superleggera) on SS19.
Jones, who sacrifices weight advantage and tarmac rally experience to Weeks and tarmac legend Jim Richards (Porsche 911 GT2), pushed both drivers to the final stage, recording stage wins across the day, finishing 11 seconds ahead of Richards in second.
A blistering time set by Jones on SS19, and a pace noting error by leader Weeks, saw the 23-year-old take the rally lead.
Jones will have a fight on his hands on the final day of competition tomorrow with 2007 QUIT Targa West Competition Modern champion Richards sure to come out hot on his heels in a quest to defend his title.
Cumulative Results for SS19 Coondle West 1
Pos No. Car Driver Time Diff
1......Nissan Skyline GTR Steven Jones 0
2......Porsche 911 GT2 Jim Richards +4.0
3......Lamborghini Superleggera Kevin Weeks +16.0
4......Subaru Impreza WRX Sti Tony Longhurst +1:22.0
5......Mitsubishi Lancer Evo 7 Troy Wilson +1:38.0
6......Porsche 911 GT3 Tony Quinn +1:45.0
7......Mitsubishi Lancer Evo 9 RS Peter Major +3:09.0
8......Mitsubishi Lancer Evo 9 RS Dylan Thomas +3:15.0
9......Subaru Impreza WRX Spec C Graham Furness +3:48.0
10....Subaru Impreza WRX Sti Rob Herridge +3:58.0
Edited by Guest
  • Replies 64
Yep. Pace note error hey. Sounds like tomorrow is gonna be real tough only 4 secs ahead of Richards but judging from today Jones can drive pretty damn well.
Thats absolutely farkin awesome, 1 day to go and it definately looks like at least a top 3 finish. I wonder where the Corvette Zr1 is though :3some:
He made more ground in later stages and is now about 11 seconds ahead Unofficial Results Link, he can drive alright and people need to know that he is mainly self funded and he is driving his own personal car not a paid drive, which means more when you look how well he is going.
Weeks was apparently using 2 year old pace notes, went straight over a crest when he was supposed to chuck a left. Cost him some time.
But, Steve's been reeling him in on most stages, except for a couple where there were issues.
Keep in mind, Steve is running STREET TYRES!! The standard tyres that came with the car. Weeks is using T888's, and Richards also on R-Comps.
My meager effort on a still camera @ Timberten stage (chicane 1) today
Oh, and a vid of the lambo popping flames at the same chicane (the sound that thing made is pure pron)
Massive congrats to Jones if he has indeed won it. Not bad for a 23 year old, fark me.
But give me that Lambo - I think I just had an eargasm...
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
