Hi guys, I was wondering if anyone has Hi-Flowed the factory RB25 T3 and then slapped it on a High Mount Manifold + converted to external gate by welding up the internal one?
Just a wacky idea i came up with that might have good results , ide like to know if anyone has seen this or done this before. Ive seen this on low mount mani's but nevr a high mount.
https://www.sau.com.au/forums/topic/236994-high-mount-factory-turbo/
  • Replies 52
yeah, sounds like a great idea.
You'll have the laginess of a Hi flowed turbo, that will be ever laggier on a large high mount manifold, just screaming to be defected because it in full view of the police officer.
lol yeah, the only reason highmounts exist is because the turbos are too large to fit beside the engine... it'd still be the crappy factory turbo, ready to poo its ceramic gizzards into the engine at the hint of upped boost.
Lol, please don't.
Good beer indeed.
Adriano has a point. I got a hks t45s that is a lowmount. (which is one of hks' first big turbos, similar size to a t78 I think)
Which brings the question "is a highmount really necessary for most vehicles?"....
To answer original question though, tiny high mount turbos are like showing off a small penis definitely.
I was looking into this and was advised that sticking a lot of really hot metal tube just below the bonnet can make a mess of your paint. (assuming you are using a manifold made from tube instead of a cast item)
Edited by TiTAN
Good beer indeed.
So therefore a big turbo should be highmounted, because a big penis should be showed off?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
