simply put - in a stock car it serves its purpose.
once you modify things (from tyres, suspension, wheels, more power etc) its no longer really useful and makes the car feel unbalanced.
I had it in my stock HR31 years ago, suited the factory suspension and everything well.
Had no place in my GTS-R with everything modified however
thats what it was basically designed for but like stated above each to there own opinion some dont mind having it and some lock it out.
It depends on how modded the car is also.
Mine is stock and at the moment its not doing me nay harm
Interesting Anecdotes about 4WS Cars.
Generation 3 Honda Prelude used a mechanical 4WS bar set-up which enabled this coupe to corner at blistering speeds.
Wiki states that this car came 2nd only to a Lambo in a slalom test! I've driven this car and in its day it had remarkable cornering ability. Sitting in the rear, it seemed unnerving as if you were in a slide or about to oversteer.
Mazda MX-6 prided itself on how it had a superb electronically controlled 4WS system. Unfortunately, if it ever broke down, the rear wheels developed a reputation in defaulting to a full-lock position.
Nissan R32 GT-R with its HICAS helped the Group A team to an unprecedented no. of track wins. Heavily modified R33s and R34s commonly took them off, not just for wt. saving but to give the driver more steering feel according to reports. The Nissan Skyline GTR DVD by Duke is where Dirk Shoisman and other track guys here on SAU can give better reasons than I can, as to why the system is removed.
Generation 4 Honda Prelude (VTiR model only) had an electronic 4WS system. It was not as abrupt in its adjustment of the rear wheels during tight cornering as its predecessor. If it ever broke down, the rear wheels would default to a straight position. My daily (VTiR) seems very well planted on sweepers - but not so on tight corners being FWD.
Generation 5 Honda Prelude VTiR model AU version never had a 4WS system. It was an option in Japan. Australia did however have an ATTS model where say, on a left hand sweeper, the outside or right hand wheels would automatically rotate quicker to enable turning to be tighter and for steering to have more feel than any previous 4WS set-up.
It is speculated that the ATTS system is being trialled on the new project Honda NSX.
The HICAS is more so a parking aid and used for handling / cornering perposes.
When you turn the steering wheel, left or right, the rear wheels will turn in the opposite direction of what the front are.
1st time GTR drivers will tend to 'Oversteer' the car as they are not use to the HICAS and the rear kicks out alittle.
I think it can interfere with your cornering, thats why a lot of ppl dis-like it.
4WS (4 Wheel Steer) or 4WD (4 Wheel Drive) or AWD (All Wheel Drive). I see it that it's tied in with the cars ATTESA E-TS.
HICAS is not a parking aid, its approx 1 degree of movement from the rear wheels, its for cornering and its only at certain speeds or something similar, I don't know the technical details.
The HICAS doesn't really kick the rear out as such, but it does confuse most drivers who have it when they lose control as it makes the car less predictable, that's why anyone who does circuit work will remove it.
I had some issues with it on the street, for some reason my one didn't like highway's and I was planning to do track occasionally so I spent $80 removing it :cool:
I had some issues with it on the street, for some reason my one didn't like highway's and I was planning to do track occasionally so I spent $80 removing it ;)
I find it does help with parking IMO.
I think the rear wheels turn 1 degree when the car is travelling over 80km/h.
'Kick out', as in I meant it can give that feeling as if the car was tail happy... But anyway.
But if you can get use to it, the car can be fun to drive, kinda keeps you on the edge sorta. Like you said its less predictable but I can see it would be a b!tch when circuit racing.
Im going for my 1st trackday in my R33 in a few weeks. Have had plenty of experience in my old ITR, but im a little nervous of the RWD Turbo ;)
Would you recommend removing it before the day? Or just giving it a go with it and see how i do?
Not 100% sure but i thought they turned in the same direction as the front wheels not the opposite. i remember seeing it on the Duke dvd!!! I could be wrong though.
Im going for my 1st trackday in my R33 in a few weeks. Have had plenty of experience in my old ITR, but im a little nervous of the RWD Turbo :closedeyes:
Good luck :)
It's safe to leave it there and have a go, but for track days the recommendation is to remove it, it makes the car a little less predictable especially when you lose the rear.
Its not expensive to remove but you should get a wheel alignment after removing it.
I remember reading it somewhere... along thoes lines but anyway, it turns either direction LOL!
from the person who said it was a parking aid that is incorrect to my knowledge from what i have read and i even checked it on my car whilst parked and the rear wheels do no move. from memory its something like 40kms an hour it clicks in dont quote me on that.
its for high speed cornering and high speed cornering only.
i took mine out and put a lock bar in as mine was playing up from time to time and i noticed the difference that it made.
as far as cornering in the upper eshelon of speeds it makes a big difference in my opinion which i have noticed in my car.
so in my own conclusion it is a very good idea and is a big advantage if u are wanting to get out on the track and set times but for most average people who would rather be OUT ON A TRACK drifting it is a bit of a pain in the ass
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
