  • Replies 52
Another Video...
more coming... :thumbsup:
http://au.youtube.com/watch?v=ayXOgX1HX48
http://au.youtube.com/watch?v=JK7jgidLICI
Also, Adam and Chris - I will put all videos of the day onto a DVD for you...
To everyone else, over the next week or so, i will put a highlight reel together...In the mean time, sit back, grab a beer and enjoy the raw uncut action..
That looks awsome!!! hahahahaha how do u think a non turbo r34 would hold up on the track?? i ask because i have absolutly no idea how to drift...... its just watching those vids it looks like the cars would need a certain amount of power to get those wheels spinnning for so long.....so anyone know if a non turbo could pull it off?
man you got to work on keeping your hand still lol... i got dizzy watching that last vid :banana:
Got footage thou, with a good example of how the drift track should be done by the blue S15 about 1min into that last vid :bunny:
How about you eat a bowl of d!ck... :banana: haha
That diff is a whore. I had it before you, Majanal before me, Duncan before him, someone else before him.
lol.... I had it tooooo!! Just never installed it!!
Oh btw Adam... I have two federal's (18/40/235) with your name on them for the next drift day.... just like new... except for about 1 inch on the inner edge :banana:
Swap sides and they will get you through another day :bunny: Actually anyone without the camber I have could use them on the rd as the part chewed up wouldn't touch... lol
Adam and Chris take the award for "Mad drifting Skillz" :/
Considering only 2 cars had to be towed out of the mud yesterday and I was one of them, I would have to agree.
Drift + 255 tyres + HICAS + stock power + stock weight + noob driver = Fail
Having said that I had heaps of fun, and got a few momemts where I think I got good angle ;)
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
