  • Replies 88
LOL @ all the GTR Fan Boys, it doesnt matter how hard it was driven & launch was people are forgetting the fact that the R35 GTR was practically brand new car with less than 5000kms !! and then it breaks ?!?!? It just shows why it is half of price of Porsche's GT3 cause Nissan would of appiled cheaper parts on the car hence why we are begining to see weak transmission problems.
Im sure if you had a porche GT3 and repeatedly launched it off the limiter
something will break be it clutch, gearbox or axles
i doubt porche would cover it even if i only did 5000kms
So this is a new gearbox; the clutch (usually a non-warranty "consumable") is more integrated within a normally warrantable driveline component (the gearbox).
Hence the ambiguity on this.
I have no problem replacing a clutch outside of warranty, most people don't. Clutches CAN and DO wear out (at least with "NORMAL" gearboxes). It's part and parcel of owning a manual car (moreso high performance ones). Jeez the number of clutches i have been through..
Anyway what prospective R35 buyers should be asking, and potentially worried about, should we expect an R35 clutch to wear out eventually? (or any other box component really) AND WTF SHOULD WE DO IF IT DOES??
At this moment, it looks like the only fix is to slot in an entire new gearbox. A very expensive gearbox, somewhere in the order of $20k to $40k. Has ANYONE experience with these new style SMG gearboxes, has anyone pulled one apart? Probably not (yet).
I expect the aftermarket would eventually figure this out, right? Or maybe Nissan will develop a compromise solution. I have a GTR on order, and if i dont get some clarity on this issue, i don't think i can go through with the purchase. At this stage, nobody really knows how much a replacement box will cost (well, Nissan AU can't tell me anyway, not yet).
Edited by LSX-438
I can assure you makers like ORC and exedey etc will be releasing clutch replacement and upgrade options sooner rather than later. so no, if your clutch wears out you wont have to buy a whole new box. that would be crazy. the odd use of the launch control wont be a problem. but if you want to drive off every set of lights with a 1.2g launch then yeah you can expect something to give eventually. think of how many 35s are our there already. and many of them tuned for more power and many of them driven on the track or raced. Out of all of those cars I only know of this one failure.
Yes a new box (for a worn clutch) does sound crazy. This is a new type of box, maybe a clutch replacement is a lot more involved? Maybe a stuffed clutch breaks other components in this type of box? Does anyone actually know? I don't think the sky is falling in but I need to know (appropximately) what major consumables cost to replace. I'm not going to drive this car to pick up a latte on Saturday morning whilst onlookers masterbate over it. This thing is going to be thrashed within an inch of its life (at the track) i expect consumables to wear out.
The factory clutches should last over 100,000 klm with the car in factory spec. As they're wet clutches (bathed in oil) I see no reason to doubt it. Similar wet clutch technology has been used with virtually no issues on various machinery for tens of thousands of hours for many years. It sure wouldn't stop me from purchasing one, and regardless, by the time something needs replacing the aftermarket will have caught well up.
You have my eternal respect...
exactly.
look at 32-34 GTR transfer cases. they use a wet clutch pack type system to send drive to the front wheels in the transfer case. that system was designed in the 80s and was pretty much unchanged from 1989-2002 and I have seen plenty of R32 GTRs with over 100,000kms nearly 19 years after they were built still with perfectly functioning transfer cases. and some of them putting out about the same power as an R35 (300awkw). yes I know the transfer case clutches are under much less load than an R35 dual clutch system as it's being used all the time but these cars cop plenty of launches etc too which puts it under big load. my point is they certainly can and will live a long happy life. considering the 35 set-up was desgined 20 years on surely there have been improvements in design and materials so it should be even more durable than the 32-34 transfer cases.
apart from all that I know of at least 3 companies looking at the 35 gearboxes and trying to assess what will wear or break in order to develop aftermarket clutches etc for them.
and even if the DSG does cost $20,000. it's a pretty fancy piece of kit. and hey a basic hollinger sequential costs you $20,000 for openers and you still need a few bits to make it work, and I know which one gives better performance and the hollinger still needs regular tear downs and rebuilds too.
Americans need to learn mechanical sympathy (well any sort of sympathy ).
I drive a Suby with a "glass gearbox" just need to learn how to drive it without blowing the box, LC isnt a good idea in AWD cars. If I owned the car Id disable it permanently, Nissan should probally alter the LC behavoiur, program it to get it off then line then nail it once the slack is taken up, like you do in a suby, a few tenths a second slower but preserves the box
my 2c
Hi all, been reading some info about this gearbox problem with the new GTR and notice some people is going thru alot of trouble trying to claim this as warranty.
i had plans to to trade my E46 M3 for one of these but looking at it now it kinder made me think twice about it.
question is is there any way to claim this and what if the lauch control was off and the gearbox still f**ks up ?  is the gearbox reliable in this model GTR ?
Don't forget, this is a country where a lot of the Japanese manufacturers wouldn't sell their top-spec cars (i.e. turbos) because they were to worried about the warranty claims from a culture that seems to be allergic to servicing cars according to the schedule.
Unless they're hardcore racing enthusiasts, mechanical sympathy doesn't seem to be in their lexicon. Agricultural gearboxes and understressed big-displacement NA engines in floppy chassis' have let them get away with a lot over the years.
Exactly. The Evo IX had a 5000RPM rev limiter if the car was stationary, to stop full-bore launches. Apparently the fastest way to launch an Evo IX was to get the clutch to friction point so the car would roll, engage the clutch fully again to let the revs hit the limiter, and then dump it.
I don't know how true this is since I found it on a forum, without even a third party news source let alone from a Nissan web site, but this is what I've been told is Nissan's official response to the saga:
"The singular thing people need to remember is that using launch control does not void the warranty - The warranty clause regarding the operation of the vehicle with VDC turned off states that Nissan will not cover damage or failures of otherwise covered components, IF it can be determined that the use of launch control led or contributed to the failure. The act of using launch control (which requires turning off the VDC) will not automatically void the vehicle warranty. Simply put, the warranty outlines that failures or damage resulting from things such as misuse, accidents, non-factory modifications, etc. are not covered under the factory warranty.
Further, the warranty states that VDC should only be turned off to help when rocking the vehicle when stuck in mud or snow.
Nissan will not void the entire warranty on any of our cars based on one specific issue of one specific component or system, however, a part or system won’t be covered under warranty if Nissan determines that the failure was as a result of misuse, modifications, etc. (as mentioned above)."
Call the GT-R dealership nearest you to confirm, and see if you can get it in writing.
Did anyone stop to think that out of all the GTR's that have been sold thus far that there are going to be incompetent drivers and drivers who are not used to using a paddle shifter? Probably a lot of over excited over revved down changes and accidental downshifts in to first (does it allow you to?). I'd say considering its been used already to some degree in motor sport with out any or many issues thus far proves something. Until with out a shadow of doubt theres no glitches with the gearbox than I don't see why they should recall them or honour warranty's. Would probably work out cheaper to give new owners a track day to learn to drive them first lol
I believe the new GTR will not change down a gear if revs are too high.
It sure looks like this gearbox issue has been overhyped; the one or two cars (which have required a new box) O/S were probably abused. It's a fair assumption. However there will be those who WILL seriously molest their cars (especially track oriented cars) so i hope the aftermarket will come to the party within a decent timeframe.
The pictures around show stripped gears as causing the failures, or one failure anyway. I think the point is that Nissan should have designed in a weak transmission link that is external to the gearbox, or, otherwise limited stress that would likely cause internal gearbox failure.
Having gears as the weak point is not very clever, keeping in mind that the car itself is 'clever' with a host of advanced features and outstanding performance. I think that its reasonable that expectations are high for this particualar car, bet Nissan come up with a fix very shortly.
Yeah first thing rather than understand how to take care of it, class actionlaw suit. Morons.... ton of youetube clips flogging (breaking) the crap out the R35.....pisses me off
any AWD car, I do that with my suby, dial 4K slip, roll then nail it, works fine doesn't shock load the tranny near as much.
Wondering how would you go about getting a good start in a R35 without shockloading the tranny? Wonder if the LC can be reprogrammed to include slip to get it off the lime? rather toast the clutch than strip off teeth.
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
    • Apologies for the long read My R34 GTT was up for sale at the beginning of spring due to a few repairs creeping up. The strut tops needed replacing, roof and bonnet (hood) painting (yay for 3 stage pearl) and the underside stripped and treated. I sold the car which allowed me to be in a much better place financially. Leading up to the sale I was already thinking about the replacement. In an ideal world it needed to be a good all-rounder. Something I can mess around with, modify, do track days, do the school run, go on long drives etc.  Options included but not limited to... Laurel C35, Evo 8/9, Civic FD2, Impreza Hawkeye, Aristo and even an Audi S4 Avant (I've already got the Mazda 6 wagon). But there was always one car at the top of the list The Toyota Mark ii JZX110 I found an advert on a Facebook group for an example in Japan, from a seller called Jon at Rising Sun Exports. A few messages back and forth and Jon calls me from Yokohama one morning (or afternoon in his case). He briefly explained the import process, the costs involved and a repeat of the advert. After much deliberation, the price was agreed and the sale was locked in. I've never imported a vehicle so I jumped into the unknown head first. The money transfer was completed through wise.com (fees apply), very easy to use and the money was with him within a day or two.  The car suspension was raised for the vessel and the car dropped off at the port. It was 7 weeks later when the bill of lading was received and the freight invoice sent to me, followed by the export certificate a couple of days after (both digital copies) In the mean time the port had been in contact. I needed an agent to deal with the NOVA (notification of vehicle arrival) along with the tax/duty invoice, this was £75.00. The port also had a fee of £100, I'm guessing to cover the cost of the 10 day 'free storage' and for moving the car off the boat etc. They need a copy of the vehicle invoice, freight invoice and export certificate to allow the vehicle to pass through customs. The vessel arrived on Tuesday 5th August, the tax/duty invoice was generated and sent over. This is generally tax 20% and duty 10% of the vehicle value. Although the invoice came in at a higher amount than I had calculated. Once HMRC had received the payment the vehicle could be released from customs. I thought once the tax/duty was paid you could collect at any point, that's not the case. Your agent will need to book a collection slot, I requested Thursday 7th which was accepted, with a 9:00am slot allocated. It was a 5:00am start from Norfolk heading to Southampton. We eventually found the compound, upon presenting the bill of lading and some ID they released the car (they drove it out of the compound to the front ready for us to load up). The email from the port stated each slot had a 10 minute window, which seemed abit farfetched but the staff said it's not a strict rule. We were there for approx. 30-40 mins in total. A week prior to collecting I contacted my garage and explained the situation, I was able to get an inspection slot that afternoon. For the registration, DVLA require the car to be insured, for this I used a company called Adrian Flux who can insure the vehicle using the VIN number.
    • Hey guys, looking for these side skirts if anyone can help me out.
    • Wife and I are still looking for a new home. One condition was a large enough garage for a full-size lift in one bay. Now if only we could find something... We've been looking for almost a year now.
    • Thanks everyone for the ideas! Sadly, ramps are a no go for me. With young kids at home, I do most of my work late at night while they're sleeping. Starting the car multiple times wouldn't be a great idea.  I'll go see one of those new long reach low profile jacks and take a couple measurements to see if they will fit.
