I've been watching this thread with a lot of interest, great to hear the results you are getting and the lack of problems (your fuel lines haven't melted yet :).
Just wondering, with all the more advanced timing / less knock, does that change your turbo choice at all?
I mean if you had (on a RB26) a Garett 2860 (2560) -9 or -7 and were aiming for 330awkw, would you simply squeeze more power out with the advanced ignition timing?
And would this completely change the power curve or would it remain similar?
Or would you want to go for a larger turbo like a -5 to take advantage of the more power?
I'm planning to run -7 or -9 on an unknown rebuilt motor (don't think its forged) but not for 6-9months, and E85 should be possible by then ;)
i think you will still have the about the same lag that you would have with pulp 98... the smaller turbo would be the way to go IMHO.
there is only so much timing can do for lag
I tend to agree with the latter line of thinking. Smaller exhaust housing size to keep the response right up there, but push the maximum out of the compressor with E85 and ignition timing to help.
I downsized my exhaust housing because I didn't like the lag and was content to aim for low 300's vs. the mid 300 potential of the larger housing - and it looks likely that E85 will give me mid 300's anyway :D
What about the fact that, as mentioned here many times, you need to use more E85 compared to 98, this would create more exhaust gas's and then the smaller exhaust housing would create a restriction?
I disagree. why.. I don't know.
I tuned a BF F6 with the usual mods, was making 347rwkw on BP98 on 15Psi of boost, changed over to E85 and we ended up with 398rwkw on 17psi. The car actually ran 412rwkw at summernats.
From what I've seen it requires %28 more fuel to get to the same AFR as BP98. Its obviously a much slower burning fuel(as most alcohols are) so in only applying the fuel changes to the tune the boost crept up about 3psi over the pump tune. The XR6T's run about 12deg total advance on 15psi on pump with the right mods and I was able to advance the timing another 4degrees and add 2psi of boost. More timing netted no reward so I left it at that. I could have leaned it out but the customer was happy at that.
My thinking is that with good fuels you can choke the exhuast side up (put on a smaller housing) without loosing any power. Remember your still flowing the same amount of air on the cold side to get to the required horsepower you just need more fuel as the specific density is less and so is the rate of vapourization. The other thing to note is that exhuast backpressure reduces with greater ignition timing so choking up the exhuast side on good fuel may yeild exhuast backpressure equivalent to a larger housing on pump fuel with less advance.
Overall it took me about 10min of tuning on E85 to realised this stuff is good. If the fuel system is large enough it will get results similar to that of VP109 - which is about $200 per 20 liters.
I downsized my exhaust housing because I didn't like the lag and was content to aim for low 300's vs. the mid 300 potential of the larger housing - and it looks likely that E85 will give me mid 300's anyway ;)
I agree that having good response is all good, but traction becomes a real issue if its too snappy, RB25det (Lee's) car is a good example, try getting him to lower the boost, yeh right, no chance!!
Hi Rob82, which side of the fence are you sitting on, do you think smaller or larger turbo than whats been tuned for 98 is better! lets say for the road anyway?
smaller
Damn straight boost stays where it is......In saying all that i reckon the larger rear housing would be nice with E85 a touch more linear (theres no way i would consider it on 98).
For street use - I would always go with more response/torque than top end horsepower so smaller turbo or smaller hot side or both.
My thoughts are that you should select a compressor that will flow enough for the desired horsepower. The selection of the exhuast housing has alot to do with the fuel being used as you can generally make the same horsepower on a better fuel with a smaller hot side than on pump pump fuel with a larger hot side, this way your maximising torque/average power. Turbo selection has alot to do with exhuast back pressure. The more the backpressure the more the stress on the engine but if your fuel is good enough to put up with it than its not a problem.
Bigger turbo's genreally mean more horsepower at a higher rpm which means redesigning the engine package. Are the cams big enough, will the head flow enough, will I need more cubes for the power to be usable etc etc.
Interesting debate so far, it will be interesting to see if some of these results are fed into something like the turbo thread...although I guess there's not many people using E85 so not many results yet...
Personally I'm thinking what would be the difference on a RB26 between Garett 2860-7 and -9 or would a smaller turbo be more appropriate for the E85?
In regard to the more fuel argument, even if you do get more fuel in there, the cylinder's the same size so the exhaust gases would be the same volume (unless more volume of air was in there) or would it be less because you know have more fuel and less air?
I never was that good at understanding engines ;)
I posted this a few pages back, have a read. The only thing i will say is that E85 will clean all the rust and gunk out of your fuel tank and system so you will need to replace the fuel filter a few times in the first thousand kms or so.
http://www.tamparacing.com/forums/green-mo...anol-myths.html
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
