Yeah still blows me away....You wont be dissapointed thats for sure
What really blows me away is it's making that power on 'mere' Nismo 555cc injectors and standard fuel pressure (OEM reg still fitted) Absolutely crazy results!
not to mention a std air box
his injectors are maxed out tho, he should think about an upgrade, i suggested sard 850's would give some nice headroom,
my 740's have a little more left in them but it suprises me how similar the settings are between the 555's and the 740's, I wonder if there really that different??????
posted in the wrong thread...
now editing with random letters as i have nothing constructive to add..
kdgf;IKGHDSLGNLdgFL;HGvugn'fug RPOTUGP'roug
fopgur
y ur
pyby
urebnp
YUEFRPYOUNBYUPYOU
yu
EYU
nryu
anyone want to answer my questions on the last page :D
really interested thanks
Well my guess is nothing else. In fact -standard turbo you might not even need injectors - give it a try and see how far your standard injectors are pushed.
im limited in terms of ecu's because my car is auto, getting a remap to run on 98 for the moment, so would i be able to do another remap to run the e85 or would i need a standalone computer to get it perfect, i.e fuel economy and reliability
also, wat if i mixed 10% e85 with 90% 98Ron, would i need a tune, ?
thanks
you will need to get a remap every time you change fuels...
so if you intend to keep changing around as i do then you will need an ecu
kool thanks, il jst save for a standalone computer that can run an auto car and other mods, until e85 is more readily available
Yeah i hear what your saying there Ad, a bit of headroom would be nice.
finally fitted my new pump and injectors. did some initial street tuning tonight, so far so good. duty cycle at 50% on 18psi so lots of scope for more boost and timing. hope to put it on the dyno in the next couple of days. i'll put up the dyno sheet asap.
Hey guys,
I keep reading this thread and it gets me thinking!!! UhOh!!
so since my engine is in the shop at the moment (RB26)
i was considering having the compression bumped up a bit to make the best use of this fuel..
Currently i am going to use 86.5mm Mahle Pistons c/r 8.5
what would be an ideal ratio for a dual setup perhaps just bump it up a little??? i'll run 98 and e85 (can store multiple maps..)
Cheers
Also
e85 locations in Sydney? i'm in Bankstown area.. google is crap for finding this stuff.. just finds a bunch of hippies raving on about sugar
Edited by Angus Smart
Here are the ones I know of:
E85 based on Manildra ethanol :
Shoalhaven Ethanol Fuel
215 Kinghorne St
Nowra NSW 2540
Ethanol Fuel
(near McDonald's) 251 Princes Highway
Albion Park NSW 2527
Ethanol Fuel
2 Rawson St
Granville 2142
Ethanol Fuel
987 Hume Highway
Lansdowne 2163
Foristville Ethanol
Warringah Road just north of the Coles Express Station. (to be verified)
E85 based on CSR ethanol
United Service Station
127 Victoria Rd
Rozelle NSW Sydney
I am trying to keep my Facebook Group as up to date as possible with the stations selling E85 check it out (link in signature)
If anyone can give me any more than that I will add them to the group details
Cheers,
Dan
e85 is back in the toy, ohhh man i love this shit. Getting the car tuned back to e85 was suprisingly easy with the vipec, seriously took 30 seconds with the software at the servo and we were on our way.
i was kinda annoyed because i got Dr Doof to come out with me to drive the car while i re-tuned it on e85, once i changed a few settings everything was running normal because the Closed Loop & Open Loop lambda correction became alive and is working 100% - better then it did on 98 for some reason?
so 30 second change over with just a couple of flat spots that needed taking care of.
Vipec suprised me again last night. what a ecu... :)
You and Doof are spending a lot of time together lately :)
Can one of you guys tell me what compression ratio would be ideal for a dual setup.
i have mahle's 8.5:1 going in at the moment. obviously i cant drop too much valves and the likes will hit? (i have no idea)
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
