is this motor run on pulp too? if so what's it make on that?
i know of a few stock rb25's making 350ish on pulp that are still holding together...
i'd like to shoot for higher figures, but in reality, anywhere i go from here just means lag...
and softer, more expsensive tyres LOL.
my car made 350rwkws (22.5psi) on BP98. 318rwkw on only 17.6psi. Id certainly give 400kw a go with e85, only if it becomes available in my state at the pump tho.
has anyone used e85 on a NA engine without bumping up the compression? how would it work? any ideas?
DO IT... i love tuning turbo hondas for exactly the same reason, super responsive revvy little fkrs.
SOMETHING NO ONE HAS MENTIONED IS OILS AND COMPATIBILITY WITH E85
Consider using oils that are methanol safe. Ive been speaking to a few engine builders and machinist involved in E85 powered race cars (hint) and wear is UP TO 20% FASTER than experienced on "normal " fuels.
So what 'street' oil is suitable for E85?
I've been running E85 is one of my cars for almost 3 years, that's around 80,000 k's and it uses my standard oil for RB's, Castrol Edge 0W60. The usual oil change interval is 8,000 k's and, not that looks is everything, but it comes out of the engine looking much cleaner than it did with Pump98 in the same engine. It also doesn't smell of stale/burnt pertrol.
For the drag cars using methanol I used to change the straight Castrol W50 (now Edge 25W50) every race meeting and I notice the sprint cars guys do the same.
In the race car using E85 I will be sending the most recent drain of Castrol Edge 0W60 to Technical for analysis. Asside from the usual engine condition diagnosis it wil give me some idea of how often to change the oil in it.
Cheers
Gary
20 % more power = 20% more wear ?
I guess it depends what "normal" fuel they were on before and the power levels.
No they are getting the same power as they were running sunoco before. I cant post up the details as they wish to stay anonymous. One of the V8 supercar teams we went and did a corporate day with also advised / warned me they have also revised thier O/H strategies for E85 too.
Edited by URAS
Interesting. I would have thought E85 to make at least a little more power then the Sunoco.
Have they given you any idea on what area's are increasing in wear ? piston rings ? bearings ? etc ?
i consider 10-20rwkw close enough to same @ thier power level.
It tends to be a boutique oil issue, and ive since heard that 300v and E85 issues may be based on one workshops experience (feedback to link) so i might look into the 300v thing abit more.
Just going to throw this out there...
With my motor (SR20DET) I run a 30% toluene mix as the motor was making enough power to trap 131mph in a 1200kg car, and im making 80rwhp more now. If i replaced the toluene with ethanol does anyone have any educated guesses what would happen to:
1. knock resistance
2. power
3. fuel consumption on full load - i.e. would it use more fuel with the ethanol than it does with the toluene on full load
It seems both ethanol and methyl benzine are great knock resisters when added, but now with toluene at around $2L im wondering if it would be smarter making a shift to adding ethanol instead.
Cheers,
Ahmed
With the current turbo combo it has been tuned to E85 only. TBH cant see him even considering 98 at this stage with E85 available at the pump again in SA.
I hear what you are saying about more power=more lag and for that reason i'm keeping my HKS3037 on my car also at 2.5 litres.
A 3 litre would be nice one day tho with a XR6 turbo 1.06 rear and .7 front. Would make some decent power on E85 i would think (pipe dream at the moment). Or i could tune the BF to E85 and have the 2 tunes on my XCal (pump and E85)could be a cheaper option but a broken daily doesnt sit too well with me.
Edited by RB25DETS2
you will need to re-tune the car. where are you located? i can suggest a tuner with E85 experience
1. knock resistance
2. power
Cheers,
Ahmed
Do it Ahmed :)
But for the your power level you'll need another fuel pump and bigger injectors.
To give you some idea I get 200km's to a tank of hard driving. 1600cc injectors, 2 x 044's and 503hp @ wheels.
On pump fuel I used to get around 330km's, and about 300km's on my toluene tune (1000cc injectors)
But, cooler water temps, EGT's....car runs beautiful. Can't beat it!!
Ive been using 300V in my engine and is dropped every 2-3k. And before every track day.
Comes out a little milky due to the condensation caused on startup/warm up.
Just got back from J-land with some nice goodies to throw on the car :)
A few gear knobs, Top Secret, Nismo. Some shifter extenders, never seen them before so ill give them a go.
Tomei Trax 2 way LSD
GTR Rocker covers.
HKS Bellmouth, picked up from Garage Saurus, my favorite, looks horn in the engine bay.
There was a titanium one at WELD but they wouldnt sell it, and we threw down alot of money too!
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
    • Run some injector cleaner through it I had a similar issue that plagued me for months, even tried replacing the cat. If one or more injectors are blocked up the ecu sees ping so pulls timing and makes the tune rich overall, you'll see black smoke coming out of the exhaust and like me assume it's running rich but it could only be one or two cylinders  $10 bottle of injector cleaner and the next time I hit boost it pumped out a huge plume of black smoke, cleared the blockage and then ran great, if that's not the issue it's only a cheap thing to try haha
