There are no ecu options for the M35 Stagea's yet, i'm running an Emanage ultimate and switching a second map for the e85 with the front panel dip switches. Cold plugs too, probably some of the reason i'm having issues with cold starts. Anything below 15 degrees and she wont fire.
I have to put 10% extra premium in the tank at the moment or it doesn't start. As the throttle is electronic, I cant gas it to dump some fuel. Once its running, no problem.
Next mod will be a small petrol canister in the engine bay, with a pump and injector powered from a switch on the dash. That should solve it. :)
There aren't many plug options (no cheap copper plugs available) but I would rather the colder ones for now, from what I have researched they will still give a better burn once the engine is warm and I won't sacrifice performance for a simple cold start issue. A petrol primer button in the dash seems like a better option for winter as it only needs a teaspoon to fire, I have all the parts to make it, and I don't have to pay to retune and rewire the emanage.
Is anyone else had any issues with the cold mornings lately? I understand you can just stab the pedal and dump a bit of fuel but what happens if you don't?
Mmm, my issue is with the actual cranking, once it has started (first 10 seconds) all is good, although you are right, a bit sluggish until you get some warmth into it.
The amount of steam coming out the back on a cold morning start is amazing...
there is sugarcane ethanol and wheatgrain ethanol
i find the wheatgrain to be a better product. both fuels reached the same kw, same tuner same dyno, but the wheatgrain used 2 deg less timing
then some barrel e85 is blended with 98 while pump e85 is blended with 91
Its been re-filled. I wonder if fresh ethanol goes any better like premium... :bunny:
Joey, why didn't you just take a jerry or two up with you? I got great economy on a run down to PI track for the classic meet. I'm not giving up all that killer midrange.
  • 1 month later...
Good to see!
I forgot to mention the possible variance in my comment, though hopefully E85 comes as 85% +/- 1% max.
Seeing as my car is being fitted with new turbo, Nismo 740's (overkill for 280rwkw in prep for this wonderful elixir), and the ViPEC, I hope to be one of the first in Canberra to be running this from the pump!
    • Bah! I can't see the point in custom number plates at all. I went to the rego office, fished through a box of "premium" plates (the ones that had the "not as tall" option for the front plate) and picked the one that had a 32 in it. That's the limit of the effort and cost I will put into number plates. The only plate that I'd consider paying for would be 2332, but that's not possible here because it already exists from probably 90 years ago, and it would cost a fortune to obtain it, if it were available.
    • After chasing my tail with LS results..... and cheaper than a turbo swap... How confident are you that the dyno is accurate relative to other results? How fast is the car - What MPH does it actually run? Is this similar to what people running this power would expect?
    • Hi mate I am having an identical issue with my 98 R34 GTT. The engie suddenly cuts out under load at about 3-4k, black smoke out exhaust. Almost feels like traction control kicking in. No CEL but still going to check codes later today. Car was sitting in the shed for about 5 months before hand and only idled a few times, took her out with about 1/4 tank, filled up and thats when the issues started happening.  Threw on a spare set of coils/harness and checked plugs which was no help. Recently had fuel pump/filter changed so surely thats not the issue unless condensation in fuel, I just havent had the time to drain it It's running a hi flow turbo, bosch 1000cc injectors, walbro 450L, Z32, Nistune etc... All about 2000km old.
    • I always wonder where the obsession with legal/illegal spacing on number plates in the UK comes from. Because it comes up in comments in every UK-based video I see on youtube. From my point of view all of your plates look a bit odd. Just because there are no markings whatsoever. In Australia we have the state that has to be on it. In Europe you get stamps and state logos. Yours look a bit like a throwaway draft that people then stuck with. And attached with blu tack so that it falls off at the slightest disturbance. Not trying to hate, but it's interesting how things are done in different countries. Do you have to follow a lettering convention when choosing a custom plate?
    • Hybrid sounds like a supercharger... It's half a turbo, with a belt to drive it! Oh wait, they're just called super chargers...
