hahaha yeah massive tank in your beast :rolleyes:
No boost for first few minutes of driving shouldn't be a worry at all, but after a few corners and a couple of hundred meters, the lines should be flushed and fuel in tank mixed....will be sweet. mini laptop in the glovebox with USB cable down to ECU will be a ripper, and I'll only ever bother running ethanol blends.
Only question remaining though, are we sure they'll only swap it twice a year? ie. as we come into winter, they change it to e70, then as we move back into summer, they change back to e85?
I think the majority, if not everyone that's using this fuel has their car tuned for 85% ethanol and worried about using E70, not the other way round.
So gas anyone used E70 on an E85 tune?
I might throw some E70 in and see how it looks on the dyno when I get the chance.
sorta off topic and I'm sure I could work this out with searching, but I don't know where to start to get a definitive answer...
If you suggest running 2 maps, which DOES make the most sense to do....I'll be running a ViPEC V44. Is the tuning software for this ECU free? As in, no license needed? and is it easy to connect to the ECU while parked at a petrol station after filling up to change maps?
If you had e85 in the tank, and filled up with ~55-57L of e70 from the pump, we can assume there will be no issues encountered running the minute mix between the two on an e70 map?
If ViPEC software is free without license, I think I'll get myself a shitty laptop to bring with me when I fill up, as well as having 2 tunes made up for the 2 blends. Can't justify myself paying more than $100 for a software license though.
Yep it is completely free on Vipec's website. Hell just download it now (it's a tiny file) and start playing around with it (there is base maps included) on your computer to see what it is all about.
Piece of piss to connect. Plug in USB cable from glovebox into laptop, start software, turn on ignition and your ready to rock and roll.
Posted the results already, slightly richer so no real issue. I have tried various blends but not straight ethanol.
I suggest you get a wideband though if you plan to fiddle...
No issue, if you are pushing E85 anywhere near its knock limits, you have lost power anyway. I think mine has around 2 degrees added over the 98 map.
2 degrees is fk all I run up to 7 degrees over 98 tune which is pretty common. But still doesn't ping with that extra timing. I'm not sure how close it is to the threshold but not sure if E70 would make it too close to the threshold.
1. tune car on e85.
2. fill up with random amounts of e85, e70 or anything in between.
3. more skids, less stress.
as has been said, if its tuned properly with e85 it will not knock on e70. if its tuned properly on e70 it will not be dangerously lean on e85
I just rang Caltex who told me the E85 pumps are up and running but ring the service stations and they don't seem to know much about it. End of the month I was told by the Blackburn road manager.
Its only for the new Commodore apparently. :huh:
if you are that worried, just get a siemens ethanol content sensor (like what the flex fuel cars run) you can wire this into the vipec and have the fuel map tuned as a 3D map (revs vs boost vs ethanol content)
hahahaha, let them think that...
TiTAN, I played around with the ViPEC software....other than not really knowing THAT much about tuning a car, my mind is f**ked. It was fun, and awesome to see just how simple the layout is. Can't wait to get this e85 business running :huh:
no u Andrew, no u.
It will be the Caltex on the west side of Drakeford in Kambah, and Nicholls. I'm hoping more follow suit, and that United also jump on the boat. Either way Kambah aint that far for me at all, and I think you were in Banks so it's not HORRIBLE for you either.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
