hahaha yeah massive tank in your beast :rolleyes:
No boost for first few minutes of driving shouldn't be a worry at all, but after a few corners and a couple of hundred meters, the lines should be flushed and fuel in tank mixed....will be sweet. mini laptop in the glovebox with USB cable down to ECU will be a ripper, and I'll only ever bother running ethanol blends.
Only question remaining though, are we sure they'll only swap it twice a year? ie. as we come into winter, they change it to e70, then as we move back into summer, they change back to e85?
I think the majority, if not everyone that's using this fuel has their car tuned for 85% ethanol and worried about using E70, not the other way round.
So gas anyone used E70 on an E85 tune?
I might throw some E70 in and see how it looks on the dyno when I get the chance.
sorta off topic and I'm sure I could work this out with searching, but I don't know where to start to get a definitive answer...
If you suggest running 2 maps, which DOES make the most sense to do....I'll be running a ViPEC V44. Is the tuning software for this ECU free? As in, no license needed? and is it easy to connect to the ECU while parked at a petrol station after filling up to change maps?
If you had e85 in the tank, and filled up with ~55-57L of e70 from the pump, we can assume there will be no issues encountered running the minute mix between the two on an e70 map?
If ViPEC software is free without license, I think I'll get myself a shitty laptop to bring with me when I fill up, as well as having 2 tunes made up for the 2 blends. Can't justify myself paying more than $100 for a software license though.
Yep it is completely free on Vipec's website. Hell just download it now (it's a tiny file) and start playing around with it (there is base maps included) on your computer to see what it is all about.
Piece of piss to connect. Plug in USB cable from glovebox into laptop, start software, turn on ignition and your ready to rock and roll.
Posted the results already, slightly richer so no real issue. I have tried various blends but not straight ethanol.
I suggest you get a wideband though if you plan to fiddle...
No issue, if you are pushing E85 anywhere near its knock limits, you have lost power anyway. I think mine has around 2 degrees added over the 98 map.
2 degrees is fk all I run up to 7 degrees over 98 tune which is pretty common. But still doesn't ping with that extra timing. I'm not sure how close it is to the threshold but not sure if E70 would make it too close to the threshold.
1. tune car on e85.
2. fill up with random amounts of e85, e70 or anything in between.
3. more skids, less stress.
as has been said, if its tuned properly with e85 it will not knock on e70. if its tuned properly on e70 it will not be dangerously lean on e85
I just rang Caltex who told me the E85 pumps are up and running but ring the service stations and they don't seem to know much about it. End of the month I was told by the Blackburn road manager.
Its only for the new Commodore apparently. :huh:
if you are that worried, just get a siemens ethanol content sensor (like what the flex fuel cars run) you can wire this into the vipec and have the fuel map tuned as a 3D map (revs vs boost vs ethanol content)
hahahaha, let them think that...
TiTAN, I played around with the ViPEC software....other than not really knowing THAT much about tuning a car, my mind is f**ked. It was fun, and awesome to see just how simple the layout is. Can't wait to get this e85 business running :huh:
no u Andrew, no u.
It will be the Caltex on the west side of Drakeford in Kambah, and Nicholls. I'm hoping more follow suit, and that United also jump on the boat. Either way Kambah aint that far for me at all, and I think you were in Banks so it's not HORRIBLE for you either.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
    • Are you 100% sure this isn't tune related?
    • 140-150 across the board. At this point hoping the grounding harness fixes it. My grounds are all tied to the chassis and none to the battery. For SR and KA that’s never been a problem for me but had a few other guys here and Reddit who told me RB really like a very solid ground setup tied to the battery so going to try that next, I’m stumped if that doesn’t do it. Never had a car have spark and fuel and not fire off before. Only thing I can think is the spark is intermittent/weak because of grounds nothing else really makes sense at this point
    • I am having close to the same issue. Can you help me with what wire you grounded to get your pump to trigger?
