I'm very much limited to what NIStune can do.
Other than the fact that I would have had a bit more stuffing around to sort nistune on a 33, this is why I spent the bigger dollarz and went with the ViPEC :)
OK so since it looks like nobody want to buy my rims lol, I'll probably get myself new a new CAT of some description, and a wideband from wbo2 in the coming months....
and some ku36's, coz these Maxxis tyres SUCK with power.
sorry if this has been covered earlier, my wideband doesnt read in lambda so im stuck with the gasoline calibrated AFR's.
what ive read is you divide your GAS AFR by 1.5 to get your actual AFR on E85.
it looks like the AFR's on your GAS calibrated AFR dont change too much, ive ripped a table from: http://www.e85forum.com/ntopic777.html&amp...721aef0b42b578a
Idle/Cruise = 14.7 - 15.2
Light Load = 12.5 - 13.2
Pre-WOT load = 11.5
WOT = 11:1 - 10.5
these figures are for gasoline calibrated AFR's.
does this sound right to the pro's?
update on my E-Flex adventures.
Car feels AMAZING to drive, more torquey, smoother throughout the entire rev range.
290rwkw with siemens deka 550cc injectors, walbro pump. still more left in the injectors, and pump seems to be keeping up just fine.
i ran a walbro the whole time i was on E85, 740cc injectors - never any issues, prob about 18months straight of exclusive E85 use - bout the same power as well
Your opinion is invalid as you have shown mental instability when you sold that absolutely amazing R34 of yours. Shame on you.
lol :blink:
Oh I didnt realise that result was on E85! Did you have a tune on 98 as well?
He only ever got his 98 tune results once I believe, and it was with a really restrictive intake so it only made 266rwkw when the piping was killing airflow.
This tune was on E-something....like E70 or thereabouts
Here's a quick excel of my pre and post caltex e flex fuel :blush:
NOTE!!! the Caltex E-Flex was actually run with LESS boost
PULP 98 spiked up to 21psi then dropped to 15 and held
Caltex E-Flex spiked to 19psi then dropped to just under 14psi by redline (where peak power was made)
I used the formula ((Speed/28)*1000) for the revs. Not exact but very close
almost 50rwkw gain through the midrange and this is only e70 at the moment...
giggity!
Yeah Pat your results make me cry. LESS boost, and HUGE gains in midrange. Fark I gotta get up early to fix my cooler piping tomorrow, not driving my car hurts. Can't wait to make the switch as well, just gotta get a bloody wideband :blush:
fark.. you guys are still going with this :thumbsup:
I been in Abu Dhabi in UAE tuning, fuel here costs 50c a litre for 98 =) and money is never a problem for guys wanting to build cars...
how different is the Caltex stuff to the United stuff? With e85 i never had any starting issues, only difference was a extra 4 cranks of the engine and that was it.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
