  • Replies 108
I believe the R32 GTR still holds the top speed at bathurst of over 300kph.
The Mines car is a road car converted to time attack and it runs on treaded tyres.
A V8 supercar is a purpose built race car with virtually no original Holden or Ford parts, unlike the Group A days in the 1990's where they were based on modified road cars. (Look at the VE Commodore Supercar, the rear doors are even cut shorter to fit V8 rules!)
Having said all this, I belive the Mines Gtr with SLICK TYRES would be faster around Bathurst.
To give an example, I race at Barbagello in a Series 6 RX7, we are doing mid 61 second lap times, the V8 supercars are doing 58's, thats 3 seconds per lap difference. The series 6 is running on 225/50/16 treaded R comp tyres (similar tyre as Mines would use) the V8's run slicks, If you put the same slicks on the Rx7 the lap times would be very close. The RX7 was a road car converted to track car with the normal mods like roll cage, suspension, brakes and HP abour 400 rwhp. It is nothing special just well sorted.
The V8's are good for what they are, A big heavy car on a smallish tyre, they are reliable and consistant, they run fast laps at Bathurst for 6 hours.
Dont forget they Banned all turbos because they were embarasing the V8's on their home ground. If Nissan built a GTR to race Group A again the V8 supercar would see its tail lights for about 5 seconds then it would disapear unitil the GTR Lapped the V8 again.
Here is some incar footage from our racing at Barbagallo
There's only one way to settle it - we get some booze, we appoint a bookie, we get a remote control car of each, we head down the local tennis court and duel it out.
Does it matter? Not likely any of us are going to be in the market to buy either??!
:spank: well said :wave:
The R32 GT-R was banned because the Falcadores couldnt catch it. It was proved 18 years ago that the GT-R is faster!
WRONGGGGGGGGGGGGGG
Group A racing was phased out worldwide because it was too uneconomical
the gtr was never banned
people need to learn facts
i know nothing of the rules/regulations of bathurst, or really got into it at all.
but... this bloke i used to work with who claims to be a bigtime v8 supercar freak said that they brought in a rule that outlawed Electronicaly fuel injected cars and that they had to have a carby? is this why the GT-R was phased out?! or he babbling some smack to me. haha
cancel that jus did my own research
"This class banned turbocharging along with four-wheel-drive, and effectively banned Nissan's GT-R from competition. "
thanks wikipedia :)
thanks wikipedia :)
uhh.. if you read 6 posts back, you'll find your answer...
group a racing was the top echelon of racing way back when
pretty much unrestricted engine size, power, engine capacity, 2wd/4wd etc etc etc
as a consequence there were really fast cars and cars that werent so fast
that my understanding why GrpA racing was canned (like gary said - uneconomical and too vast a difference between the good and the not as good)
the japanese GT500 and the aussie v8 supertaxis all stem from the GrpA - but restricted engines, engine capacity, production based cars (so no 4wd supertaxis) etc etc
somebody correct me on teh finer points of it, but that to me is the general gist of it
group a was a group of racing for modified touring cars, but was phased out as gary mentioned, and in australia was replaced by the 5L v8 supercars, and 2L super touring cars.
edit... yeah, what ash said, everyone basically went their seperate ways, and we ended up with supertaxi's.
i'd still have one, cant go past that v8 note.
ok we can say that the r34 would be a good competitor anyone who knows anything about jap track cars would know the mines r34 would give the V8's a hard time for a 7 year old car against cars that are a year - two years old but! how about we change the rules i can bet if they put on the new r35 on that track it would tear thoes v8s a new A hole without a doubt it did it with the r32 it can do it again.
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
