  • Replies 231
Posted Images
What do you mean?
Dan and I won the event!!!
Well....we won the those F1 watch's and Ben won the day!
it was so sick watching 40 on par wrx's going around the track!!!
Not sure who won that merc....maybe NISMO?
all in all, im glad I got that watch!
What do you mean?
Yep Merc went to me chubbs.
Just to give you guys a heads up, I'm planning on keeping it and offering it as a prize for new idea i've had.
The "2 Million Dollar Driver Challenge"
Yep that's rights, it's on b!tches.
The Merc will be used as a lucky door prize.
Entry fee's as follows
First 5 entrants - $25000
Next 5, I'll tell you I'm almost booked out but will squeeze you in for $20000
Next 5 as above but $15000
and so on and so on, until the last 5 entrants will be paying $50 each.
Oh, and Breitling watches for all!
Who's in?
You know as rediculous as that sounds that may have been the only way something like this could work.
But with the proviso that the guys paying the top $$$ got to choose when they drove (aka either with the newest car / tyres or if weather was a factor then when the weather was best). And obviously the people paying the least get the crappest conditions.
OR - my other thoughts were to make sure everyone got an even go was that instead of using cars we could use a mono-rail! No tyre or weather conditions to worry about then. And all other competitors would have to ride in the mono-rail whilst each driver had a shot so weight was constant as well. It worked in Brockway, Ogdenville, and North Haverbrook so why not here as well!!?
What do we say? MONORAIL!!!
north haverbrook. why the very name conjures up romance and intrigue.
we could hold it next to their worlds biggest moon bounce or over near the ultimate fighting zoo?
  • 2 months later...
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
