The only reason its going to foul the plugs, is repeated cold starts & short drives.
ie, get in car, drive 5mins, turn off. Drive 5mins 4 hrs later, turn off etc.
Obviously ive exaggerated it a tad, but over the course of 3-4 weeks, lots of 'mini' drives on cold start does have potential to foul plugs.
Just let it sit for 30 secs, give you time to do your seatbelt up, check the oil pressure gauge is doing its thing, and any other warnings that might pop up...
and off ya go
people say that if you start your car and let it idle for 5 mins, the petrol gets through the piston rings and into your oil
+1 for gentle driving
on this note, its not about coolant reaching operating temp, its about oil reaching operating temp.
A bit off the thread but...
The only cars I've ever had to warm up (out of the 30 in my 40 yr driving life) were my precious
Alfetta GTV and
Alfa Romeo 164 Quadrifogglio
what with...
i) oil leaks
ii) exhaust manifold working itself loose from the block through different expansion rates in metal on warm up
iii) blowing universal joints
Why did I get a 2nd Alfa??
Slow Learner! Lolz. I laugh at the times that Jeremy Clarkson says that you have to own an Alfa to be passionate about cars.
What I've learnt is that by owning an Alfa, you learn how to become stoic and patient with its faults.
Tez
PS Why even my Alfa Romeo umbrella developed holes - yeh, gave it away to anothet Alfa owner. Needless to say, he's a slower learner than I am!! ;)
I would NOT use the water temp gauge as an indiction of when your car is warm.
My water temp gauge comes up to mid way and the oil temp gauge has not even moved!
It takes 7mins of easy driving to bring everything up to temp. Warming a car by letting it idle for 5 mins as people have suggested it waste of time.
I know that piston/cylinder glazing is an issue with heavy diesel vehicles (tractors, trucks ect ect), but I don't think it is a big issue with petrol engine, or even automotive diesels for that matter... I think it is more of a load issue more than anything, but don't take my word on it..
why bother waiting for oil and water temps to reach optimum?
the oils you use are multigrade winter-suitable oils... the coolant is designed to transfer heat away from the head etc... the ecu is programmed to fuel differently at different temperatures...
as for oil on the walls... the piston rings are supposed to keep the oil on one side and the combustion on the other... on downstrokes theyre designed to angle slightly to scrape oil off the cylinder walls...
if im wrong, someone please correct me on this
im thinking the only time you really need to let your car idle for a while is with forgies that get piston slap at cold temps
Thats awesome!! :D
Thanks so much everyone!!! :P
Hi Guys And Girls it's Bankzy here.
I just joined today, and i thought i might just add to this post.
When sitting in traffic for those of you who don't know this it's actually a good idea
to rev the motor a little and hold revs, maybe say between 1200rpm and 2000rpm in turn creating more coolant to flow
thrue the internals. What this will do is keep the internals cooler. BTW your car is hot Beck.
yeah. different composition, i forget what of
they expand much more when hot...
depends on clearances, tolerances, piston type etc.
not all forgies are the 'same', different properties for each brand and so on.
a well built motor, shouldnt have any audible 'slap' unless its a crap build IMO
Ditto... I use the oil pressure as a guide until i get some way of reading oil temp (ie. R35, not just a sensor :D)
If the oil pressure rises with revs, oil aint ready!
haha i only learned from a guy at work
has an 80s turbo charade
backyard performance to the max =D
I don't see how starting your car and letting it idle at any time could possibly be detrimental to your engine.
Fuel mixture runs rich, not burnt completely, excess fuel dilutes oil. You work out what happens then.
Turn it on, start driving. The engine will warm up MUCH quicker if it is doing some work. You don't need 2-3 minutes to get fluids circulating - if they aren't circulating in the first few seconds of running, then they won't be circulating 2-3 minutes later.
BTW - we discussed this a few months ago!
What utter rubbish. At idle, the engine is not doing any meaningful work, therefore it is not generating substantial heat. All you are doing is burning - read 'wasting' - fuel for the sake of burning fuel.
If it was such a good idea, the manufacturers would have designed the ECU's programming to do it for you.
    • Congrats on the career change!  I did something similar at the start of the year too, left IT / corporate after nearly 2 decades. Soooo when's the motor coming out for the spark plug change?
    • Hi guys, long time no post as per usual! It's been a busy year so far, the biggest thing being a new job.  After 28 years in the automotive industry I decided it was time for a change.  I was losing faith in the industry and where it's heading.  Now in a completely different industry (electrical) working for a company that manufacture water pump contollers.  Not as sexy as cars but it's an interesting,  challenging industry. I now don't work Saturdays which is a bonus!  It's still 50-55 hours a week but having Saturdays ack after 28 years of working them is awesome!   No news on the GT-R but i did decide to add some more JDM goodness into my life....           1990 300 ZX.  She's not perfect but for a 35 year old car she ain't bad!  Just going to tidy it up a bit and enjoy it.  It's currently auto but will start stockpiling everything for a manual swap. It WILL distract me even further from the GT-R but im hoping not for too long! It somewhat proves a 6'8" freak can fit in a 300 ZX.  Sort of...  I drove it home from the previous owners house in Melbourne via Black Spur and Merton Gap (2 awesome bits of Victorian twisty road) and it was amazing!  Handles so well!!!   I don't think it would be worthy of a full build page but I'll post up some of the upgrades here if anyone is interested?  Cheers guys!
    • End game is to: - Remove all the slop from old worn parts - Adjust setup so that the wheels actually fit and the car is drivable (currently it is not because of the extreme rubbing on the guards).   Progress over the last couple of days, removed the rear hubs! Next steps: - Buy bushings - Replace bushings/bearings on hub - Reinstall
    • Cracked deck  And other cam snap stuff
