heloo.
i have been tying to install Nismo R34 GTR cluster in my GT,
most all working accept the speedometer end the central door lock.
engine Waring light : error speed sensor. is it possible to get pic of how it the cables are connected.
regards CB
  • 2 years later...
  • 8 months later...
  • 2 years later...
  • 6 months later...
  • 2 months later...
I have just completed this conversion and have updated the Excel document. I found an error on it and also added a few missing pin outs.GTR_Guage_Cluster_Conversion3.xls I can confirm everything works on my car, it is a GTT manual. The centre plug at the back of the cluster is different between GTT and GTR. The GTT is a brown 24 pin plug and does not plug into the white GTR 24 pin socket, I modified mine to fit using a hacksaw blade and needle file. I also swapped the lense over to the GTR cluster for the Slip and TCS off lights.
  • Like 2
  • 1 month later...
  • 5 months later...
On 19/07/2013 at 8:06 AM, camperbob said:
heloo.
regards CB
Hey i know its a looogshot but did you ever figure it out becuse i havet the same problem
  • 4 weeks later...
  • 5 months later...
14 minutes ago, NZ-GTT said:
Nice work! How did you remove the pins from the connector blocks? I could not get mine out so I had to cut and solder wires.
a pin from the opposite side the wires hang out. through the inside hole.  i did this January 3, 2016 from my previous post date. the pictures are from then
  • 3 weeks later...
  • 2 months later...
  • 4 months later...
Oops good pick up! I just rechecked my pinouts and it should be 10 to 9 and 63 to 11. I've corrected the error and uploaded the file in this post as version 4.
GTR_Guage_Cluster_Conversion4.xls
Thanks for the correction!
Another thing, non gtr pin 17 and pin 46 both move to non gtr pin 57.
Can you check if it is correct?
pin 17 is rear defog signal and pin 46 is charge w.l
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
