sorry for post whoring but who owns the major old school skyline thing? the prince or car formaly known as prince?
someone should know what im talking about, get a pic of that 1 in there :( i think he's still in the middle of fixing it up though ;)
The prince + The DR30 would be great to have on there... classics deserve props
-D
  • Replies 486
Posted Images
Are there enough good cars of each generation to make it flow from the Prince Skyline GT-B right through to R35?
I'd say so... the R35, well you'd have to ask Willall for permission for pics... No problems for r31-r34's, the prince and the dr30 are both in really good condition, so it'd be a case of finding r30 and the other earlier models. which is going to be the hard bit i'd guess
-D
Matty can help us out with a photo of the prince, good mate of his owns it. 'Benny Blanco' on here has a DR30, which i would love to include, i think i have some of his anyway from a photo-cruise i organized last year.
Cheers for everyone thats submitted photos so far!
Ben, Nene, Send me some of yours! and of the GRIM aswell please :(
ill be keen for a calender, also i know its a skyline sight but would u consider a nice jzx100 chaser as a car for the calender, if not, i have very good picks of my old skyline if u want to but them on it, thanks
Can't speak for flick or public opinion, but I'd say the skylines are the main aim. A separate stag and separate other import calendar are always possible..
theres only so many photos u can have on a 12 month calendar, sadly
-D
Edited by Dohmar
would rather just not have anything
to do with the sad-act.
please let it all go and turn this thread back into chat about the calendars
shakes head, and after i came over to your house when you were new on the forums and taught you how to install dash cluster globes, ah well
someone should know what im talking about, get a pic of that 1 in there :( i think he's still in the middle of fixing it up though :)
yes Dan your thinking of Pete with the 66GT av-17334.gif<<<
^^ think that shit needs to go to pm, no one wants to read about it from either of you.
I had an idea for the cover, having the SAU logo on top with Skylines Australia under it, and then under that a sequence of taillights in the dark, so going from 31 through to 34 or even 35 maybe if we can get a pic like that. But yeah not sure if i making it easy to visualise but hopefully you get the idea.
Here's a pic I'd love to include but I want to go back and re-do it, this time with my heslo plates and standard GTR front bar, if you want to include it let me know and I'll go back and take another :(
I'd like to see some maturity displayed from here on in in this thread, therefore the hostility will cease now guys. Simple as that. The kind of comments that I have had to removed have no place on this forum.
Continue back on topic...
Good idea by the way. I'd be interested in offering my car for photograhic purposes, or at the very least owning the finished product.
i have a few pics that wouldnt mind showing but i cant upload for some reason. Could u please P.M me ur email address Flick so i can send thru or can see them on http://s284.photobucket.com/albums/ll6/scott_1982_r32/
If u want any, and they're good enough just ask and i can send thru a full res copy
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
