Thanks for that guys- I havn't been able to check headlights yet as I work away a month at a time and the guy working on my car hasn't got around to checking globes yet!
Ive attached a photo so if possible could you please confirm projector headlights?
Thanks,
Dan
32 GTR projectors are H3C.
  • Replies 102
Posted Images
All kits order now will be delivered after the new year.
In the new year i will be starting a new group buy, but this time there will be 3 brands to choose from.
I will have all 3 at my place for a test very soon.
I installed a 4300k HID kit into my friends XR6T. Here are the results:
Here is a shot of his standard high beams:
And now a shot of the low beam HID:
As you can see the difference is awesome. Please excuse the crappy pics,as it was pissing down and freezing ;)
:P
:D
very interested in getting a HID kit... what 3 brands and what prices are we looking at for the new GB??? Is 6000k street legal??
^^ Yes 6000k is legal, anything lower than i think about 4000k and higher than about 6000k is illegal. 4000k is white, and 6000k is crystal white, all the others are different shades.
I will be interested in the new group buy too, need to find more info out about these kits first to make up my mind.
Hi all,
The first group buy seemed very popular so i thought i would do another, however due to higher courier costs and exchange rates the price has risen slightly. But still the price is still very low for a high quality Helligkeit HID kit:
German name Brand Helligkeit HID Kit,
Simplified wiring which eliminates any unnecessary confusion during install.
More than 16+ bulb types.
0.3% failure rate, compared to 3-10% failure rate of other HID Conversion kits currently out on the market, the reliability is comparable to that of OEM HIDs
Color temperature output has tolerance of +/- 100K, the tolerance is unnoticeable by human eyes
Superior lumen output compare to its competitor
Best quality burners from Hella
Choose from 6 different color temperature, you will indefinitely find the color output of your choice German name Brand Helligkeit HID Kit, simplified wiring which eliminates any unnecessary confusion during install.
The price is $135 Delivered anywhere in Australia
Please PM me with your order and specify what temp and bulb type you would like.
3000K(Golden Yellow), 4300K(Crystal White), 6000K(Diamond White), 8000K(Diamond Blue), 10000K(Aqua Blue), 12000K(Brilliant Blue)
Group buy ends 31st of December, please PM me for an order :O
Hi i looking for the stock Xenon bulb for an r34, would you have the bulb i need?
    • I was using the wiring diagram I have So 12.74V is coming into the rear Fuel Pump relay as I measured.  When I turn the key to ON im getting 0.6V to the Fuel Pump plug; which i assume is backfeed voltage and doesnt include the 12V from ignition power.  The rear relay is working and being triggered.  From the diagram I clearly see the rear relay 80 = Rear Relay going into the Body/H loom (R-27) 27 = Fuel Pump plug going into the Body/H loom (T-20) 40 = Short Connector (R-27) I'm reading 12.74V on the blue/black wire which is the power for the Fuel Pump   From this diagram I can see the Ignition relay goes into the front and up to the ignition  2 = Fuel Pump Relay <1M> (R-27) 37 = ING Relay <1M> I started from the pump using this reference Which the way I read it (referencing Nissan wiring color codes) is: Pin Wire Color Function 1 B/P (Black/Pink) Ground 2 L/W (Blue/White)        ECU Trigger 3 SB (Sky Blue) Fuel Pump 5 L/B (Blue/Black) 12V Constant Tested SB to SB on Fuel Pump for continuity - confirmed Tested negative on Fuel Pump to 12V battery and L/B - confirmed 12V Pulled the relay putting 12V between Pin 1 & 2 and testing continuity on Pin 3 & 4 - confirmed relay   So that has me looking at this part of the circuit to understand whats happening here...and im still confused. From best I can tell; the disconnect is back to my previous diagram; between Ignition Relay and Fuel Pump Relay...which yet again; afaik is where the immobiliser should.    Thats what I was trying to explain to GTSboy; im not trying to fix it myself; yet I seem to have to get a Masters in Electrical Engineering (while im busy doing my actual job of DevOps & Cloud Engineering) somehow.  I just wanted more expert opinions; or more so that what I tested is correct and proves it to something around that area; to go back to the alarm tech (for a 3rd time) that he needs to fix it. He keeps telling me its not the alarm. He lives on the complete other side of the city so i understand not wanting to make a trip but as I said before if its the alarm it should be up to him to fix it. But he's adament its not; even though I pointed out the FP was immobilised through the original alarm. To my mind; it seems that the ECU is sending the signal; but the ignition is not getting 12V down the line.
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
