That's what I used to clean just inside the ports... but I was too worried about debris/bits of metal bristles getting in the cylinders to go any deeper
Vacuum clean as u go.
Edited by 66yostagea
https://www.sau.com.au/forums/topic/243609-s1-turbo/page/3/#findComment-4258007
  • Replies 51
I finally got the manifold off. The back banjo bolt on the turbo nearly deconstructed my shoulder reconstruction. No lol.
The turbo appears AOK. There are four broken studs to get out.
Nos 1, 2 and 6 exhausts were all leaking past the gaskets. I got a new set of gaskets, studs and nuts from Nissan. $247.00. I dont know yet how much to remove the studs, I just hope that they can come out without taking the head off.
In the meantime I am enjoying driving my "New" RMR30.
https://www.sau.com.au/forums/topic/243609-s1-turbo/page/3/#findComment-4262475
Wow, sorry to hear you had a much harder time getting your manifold off then I just did. Seems that this little procedure is much harder to perform on an R33 engine than an R34? Maybe it's just because of K's/age; how many K's had yours done? Mine was 110,000...
I bought new exhaust manifold gasket, studs and conical-locking nuts from Nissan and my total was ~$192; I know that turbo-manifold gasket is around $40-ish though, and a dump gasket is the same.
The turbo water and oil lines SUCK, in my opinion... I'm going to do as suggested and take the solid oil line to pirtek and get a braided hose made, hopefully around $60-ish, to make things a bit easier to put back together. Hopefully I won't have to use banjos with it still, because they also suck (fiddly copper washers to get on).
The temptation is there to replace so many things while it's apart... just think... all that work to get back here again to change turbo, gasket, manifold, dump, EGO sensor etc. etc.
Edited by DaveB
https://www.sau.com.au/forums/topic/243609-s1-turbo/page/3/#findComment-4264745
Yippee. Justin came over and got the broken studs out in situ. If anyone needs a similar job done call 0407768450.
Incidently his set of L/H drills, 4 off, cost $350.
https://www.sau.com.au/forums/topic/243609-s1-turbo/page/3/#findComment-4268748
I read that you have your turbo back on... how'd you go with it, are you driving the car again? Was it a GCG hi-flow you put on?
No, the turbo was OK, so I put it back on. I am pretty sure the problem was a loose hose on the turbo inlet rather than the leaking exhaust gasket. The noise only occured when the boost came on. With the brakes on I could run up to about 5 psi and it was very noticeable, at about 2k+ revs. At 3-4K in park, ie no load, no boost, the noise was not apparent.
Finished the job yesterday and it drives like a Stagea should. I also cut the corrugated part of the hose between the AFM and the turbo.
I will keep the stock turbo I bought and get the mannifold repaired so they will be good to use if needs be.
https://www.sau.com.au/forums/topic/243609-s1-turbo/page/3/#findComment-4291763
glad to hear you're now one of the lucky ones who's factory ceramic turbo is _not_ whining its head off!
Did you replace the corrugated part of your inlet pipe with a metal tube (as mentioned somewhere here in a '5 minute DIY' or something similar)? Also helps stop 'sucky closed under boost' though you probably won't have that problem with the factory turbo I guess.
https://www.sau.com.au/forums/topic/243609-s1-turbo/page/3/#findComment-4294679
I did the inlet pipe bit.
Each time I do a bit og mod the car gets better. Went for a run out the back blocks today. Very satisfying.
https://www.sau.com.au/forums/topic/243609-s1-turbo/page/3/#findComment-4295573
    • I'm selling my personal race car. 1992 BNR32 Skyline GT-R About eight years ago the engine developed the dreaded low oil pressure problem. I removed it and found the issue. However shortly after I moved half way across the country, moved my work shop, bought a house, got married, then moved my shop again to it's permanent location for the time being. in turn I do not have the time to race this car as it should be. In turn the engine I built for this car will end up in my street car and this car I hope finds a home with someone who can use it to it's full potential. The roll bar was built by Jason Noren Fabricaiton in Pomona California to SCCA and NASA Specs. The car used to compete in redline time attack and global time attack enthusiast class. It also has a fire suppression system.  The car is with me at my workshop in Kyle Texas, USA. Shipping it is no problem, I can personally deliver the car to the port of either Houston or Los Angeles. Any other port depending on where it is may require transport but we can always work that out.   The chassis itself is rust free, rear quarters and under fenders are free of any rust so it's a very solid foundation for anyone who wishes to move forward with it. As posted and at the asking price of $20,000 USD the car includes all of the following;   All OEM Body panels, front fenders, rear bumpers etc.  OEM Nissan Projector headlamps (Pictured N1 lamps were removed) OEM Nismo Side Skirts / Extensions OEM Rear Spats  Front & Rear Subframes are installed car is full roller Rear Subframe has Cusco Camber Arms, Whiteline HICAS Elimination Front Subframe has Whiteline tension rods and whiteline Sway bars w/ endlinks.  Buddy Club N1 Coilovers All chassis wiring and engine wiring is in tact. Attessa System is fully in tact and was functional before engine removal.  BCNR33 GT-R Brembo Brakes F+R with Endless MX72 Plus Pads, DBA Rotors & Stainless Steel Brake lines Billion Racing Radiator Billion Radiator Hoses Fluidyne Engine Oil Cooler Accusump System (trunk Mounted) 5 Speed Transmission w/ Transfer Case F+R Prop-shafts Rear Differential With rear Axles.  Nismo Gauge Cluster Nismo Clutch + Flywheel   Essentially what is needed to make this car running and driving again is as follows: A working Engine, an ECU, and time to put it together. The price posted is or best offer as I am willing to remove some components to accommodate price to a certain extent. If any serious buyer wants full detailed pictures, videos, or any questions I'll be happy to answer them. I believe this car is priced to move quickly considering it's a rust free and very straight chassis but always open to fair negotiation.  I can be contacted via phone or email. (+19517081648) email is [email protected]
    • So...to my (and my mechanics doing the swap) surprise...the oil pan from NEO engine does not fit 100% and needs to by modified like this: It is not a huge problem but in the future i want a "proper" oil pan. So question is...what different oil pan can i get to fit without any problems and modification? Thanks!
    • Some more info I found.  These are the last entries Yoshikiyo Fujii made on his blog before he passed away in 2009: http://blog.livedoor.jp/fujii_dynamics/ And finally this is where the workshop was situated:  https://maps.app.goo.gl/HhTPtHzt3WVcBTiEA
    • shit boxes, kids, and daily drivers are all welcome
    • Cam seals go hard. It's a very old car.
