  • Replies 75
I'd be intereseted in these parts if you have them. I am located in the US (zip code 07657) but I figure the parts are small and easily shipped. Let me know please.
Pssenger side triangular rubber piece that covers the interior side of the side mirror and also the plastic trim that goes around the interior door handle. Thanks.
Edited by anubyss
Yup i've got those. Pm sent
pm sent mate
Pm replied
Few bits sold: front seats, dash surround, window switch surround, HKS FCD, left tail light, chrome door sills
front and rear strut braces, rear springs/shocks, bonnet, grille, right tail light, gearbox, tailshaft, inst cluster, drivers window motor & apexi pod all sold!
Lots of bits left! Pm me if you're after anything
thanks for the apexi pod & gfb bleed valve mate. left you some trader feedback.cheers
cheers :D
Pm replied
no mate i havnt got a pm bak
Sorry I must have missed it, pm sent
  • 1 month later...
  • 1 month later...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
