32's have done Pikes Peak also, won the Production class one year I think too?
Murray Coote told me back in the early nineties when I posed him the question that weight was a major factor, as was the general complexity of the GTR in comparison to period cars. I think he said suspension travel might have also been an issue?
But the goalposts have kinda moved these days haven't they, even Evos and Sti's are north of 1500 kg now.
Maybe one would be ok, but I still reckon they'd be an understeerer, what with that big cast engine and diff hanging out the front. I'd LOVE to see and drive one though! :P
https://www.sau.com.au/forums/topic/245571-gtr-rally-car/#findComment-4273134
Maybe one would be ok, but I still reckon they'd be an understeerer, what with that big cast engine and diff hanging out the front. I'd LOVE to see and drive one though! :)
Complex as the center diff ??
Can you run the older style center diff in the 32 (Viscous)?? Would like to get a way from all the electronics.
Yer the weight may and may not be a limiting factor, in my searches they seam to be around 100kg heavy than the Rex/ Evo and only 100mm longer.
Travel could be the problem the Nissan GTRi had the same problems
Would love to find some body that has done one before.
Cheers
Ian
https://www.sau.com.au/forums/topic/245571-gtr-rally-car/#findComment-4273905
Every time my mechanic took my gtr for a drive around the block to check things after servicing it he would always try to convince me to convert it into a rally car (he works on 1600's & 1200's rally cars all day long).
https://www.sau.com.au/forums/topic/245571-gtr-rally-car/#findComment-4275523
just a gts i believe.
Hey!!! Just a GTS, geez!
I've wondered about the GTR on gravel thing. I know a guy down south ran a GTS4 (ours are turboed) as a rallycar. Never really saw any results tho.
I would beleive that a GTR or GTS4 wouldn't be very competitive next to Evo/WRX's due to the heavy RB. Plus, the other two cars have had over a decade of development in this form of motorsport, so if your Evo doesn't do something right, there is a stack of info of how to sort it. For a Skyline there is pretty much none.
https://www.sau.com.au/forums/topic/245571-gtr-rally-car/#findComment-4279180
Cheers
Ian
there is no centre diff in any GTR. 32 33 or 34. they all run the same type of transfer case with a wet clutch pack type arrangement to send drive to the front. the only difference is in the way the computer controls the transfer case pressure and how fast it samples the data in the different mddels.
32 GTRs don't make good dirt rally cars for a number of reasons.
heavy = 1500kg
big cast iron block inline 6 up front not good for balance
possibly too much RWD bias
cannot fit 15 inch rims over the standard brakes, and you would really need bigger than standard brakes anyway for some serious competition
cost of running one as a dirt rally car would be pretty high.
not much available steering lock
it would be fun, and would look and sound awesome! but there is every chance you would be quicker for much less money in a wrx or evo on the dirt.
tarmac rallying is a whole other story though... :D
https://www.sau.com.au/forums/topic/245571-gtr-rally-car/#findComment-4279386
heavy = 1500kg
tarmac rallying is a whole other story though... :blink:
WRC cars run up to 16in wheels on gravel and they have some pretty awsome brakes, I would say far superior to factory GTR ones. You don't need hugh disks to have good brakes.
Cost of running any rallycar ( or motorsport in general) on gravelis expensive!
I don't beleive that WRX's have fantastic steering lock either, generally in a 4WD rallycar you are not that crossed up, straight is fast. RWD is a different story!
A heavy car can be a good thing, we have a lot of old VR4's out here rallying quite competitively, and their weight makes them very stable.
But yeah, the big cast irom block foward of the front wheels causes most of the issues. You need a well ballanced car for gravel, but a lot of this can be overcome with carefull suspension setups, crutial in 4WD's.
https://www.sau.com.au/forums/topic/245571-gtr-rally-car/#findComment-4279628
hey mate, yeah I know WRC cars run 16inch rims on dirt/gravel but we are not talking a lightweight WRC car, with unlimited budget for suitable offset wheels to fit the required brakes with their latest tech calipers pads and rotors. we are talking a 1500kg 20yo 32 GTR. and for people with a budget, you will almost certainly need something better than the factory 296mm rotors and 4 pot callipers to pull the thing up. I know the dirt stuff may not be as hard on the brakes as the circuit/tarmac stuff but i still don't reckon the stock gear would be up to it. plus as alan said he wants to run 15inch rims so he can use the readily available tyres he wants. most off the shelf 15s will not fit over the stock 32 GTR brakes let alone any upgrade.
anyway considering how cheap and tuneable 32 GTRs are to purchase I would say if they were any good at dirt rallying there would be dozens and dozens out there by now.
like I said, it would look and sound awesome, but results wize you'd be better off following the pack and jumping into an evo or wrx as all the development has been done, parts available and results proven. :ermm:
https://www.sau.com.au/forums/topic/245571-gtr-rally-car/#findComment-4280041
  • 2 months later...
Also need to consider the effect of Turbo restrictors, For a single turbo you need to run a 34mm restrictor (Group N is 32mm), which means for each of the GTR turbos you need to run 17mm. Yes I am serious, and it cam straight from the mouth of an ARC Scruitineer of considerable knowledge, and an R32 is the exact reason I quizzed him about it. There was talk about allowing cars to run with no restrictors if they were running AUS Pump Fuel, not Elf etc but it is some time since I have heard anything on that front.
https://www.sau.com.au/forums/topic/245571-gtr-rally-car/#findComment-4439194
Just one thing about that, the 2 restictors are 24mm not 17mm. Its the cross section that matters not the diameter and 2x24 is about the same as 1x32. Still a tiny hole for a GTR to breathe through and you won't make more than 250kw whatever you do with it. Exact same rules apply for Improve Production circuit racing.
https://www.sau.com.au/forums/topic/245571-gtr-rally-car/#findComment-4440021
4WD rally car means you need restrictors
Will they let you run a >2L turbo AWD? What category would it fit into?
You can get 16" rally tyres. There are heaps of brand new Bridgestones for sale on Ebay for $200 a pair. Buy a dozen pairs and you're set for a few years of rallying
The stock brakes are heaps bigger than many other rally cars. A decent set of pads and airflow and you shouldn't have a problem in the dirt. Not like you're going to be regularly pulling up from 200kph
The ATESSA will need to be tweaked to give it more FWD bias to work effectively on dirt. Sad fact is that the next best thing to true AWD is FWD. RWD rally cars are a long way behind. Of course I still refuse to believe this in my RWD dinosaur, but them's the facts. (ever seen the stage times of a well driven almost bog stock Hyundai Excel? Scary!!)
Apart from whether it will be an outright contender or not, I reckon it would be great fun. My GTSt was very nicely balanced on dirt, so a GTR sould be just as easy to drive quickly, and make for great spectating.
There was a guy running a GTR at one of our local dirt sprints late last year. I didn't get his times, but he certainly looked quick (and I don't mean totally sideways action looking quick either)
250kW is enough to scare you in the dirt anyway.
https://www.sau.com.au/forums/topic/245571-gtr-rally-car/#findComment-4441157
