Driver Dynamics Beginners Drift Day Sandown Saturday 17th January 2009
If you’ve always wanted to have a go at drifting on the circuit, but didn’t want to attend a fully blown drift day, then we have a course that will suit you perfectly.
To be conducted at Sandown on 17th January 2009, this day is aimed at drivers who want to have a lot of fun and learn plenty about drifting from Australia's best professional drifters including Adam Newton and Luke Fink.
The exercises will be conducted on wet roads to keep the speeds down and minimize wear and tear on your car.
The cost for this course is $195.00 including lunch and refreshments.
We’re taking bookings now, so if you’d like to attend give us a call on 1300 652 693
  • Replies 147
Posted Images
eek...this should be fun. how is the track gonna be set up? diff groups diff sections? learning how to link corners? semi-high speed corners? how close are the barriers again?...lol
+1 More info on the day please, Wet track ie. Large Skid Pan with cones?
who in their right mind would drive an auto sk.....oh....
I've organized early skidpan days in 2003, and there's some auto cars attended, including a benz, which are purrfectly fine for drifting.
It's the driver who drifts, not the car. If you got skills you can even drift a rickshaw if you really try hard...
yeah but basti has only had exp driving these things, and well i dunno man......skyline is a whole new ball game :)
will a tiptronic with foot brake (not hand brake) will cut it?
well if u block, by putting a chunk of wood or something there, the release lever so it'll always release the hand brake when ur foot's off it shud work.
so i'm guesing this is gonna happen in the car park? how much track time each?
is this the same as a cams event so needed is a day's cam's license and gear would be required such as adr helmet long sleeve's and closed footwear ?
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
    • Yea that's a fair assumption. I'm presuming they call them solid lifters as they have no moving parts like hydro lifters.
    • I believe you're confusing WMI with water injection. Looking at that graph, the 93aki+WMI car is making more power than C16 race gas. Boost juice, which is what I also run, is Snow Performances 50/50 premix.
