If I install an RB25DE with carbs in an early Skyline with an upgraded ignition system can I completley eliminate the ECU and wiring harness? Because it seems like the only things the ECU really needs to control is timing (which will now be handled by the ignition system) and air/fuel ratio (now controlled by the carbs).
Thanks! :ermm:
https://www.sau.com.au/forums/topic/246188-rb25de-with-carbs/
yes its a possibility
here in australia there was an early model Nissan Patrol ('88-90 i think) that came out with the RB30 but in carby form
if you could get hold of an intake manifold it could be possible to install a big holley 350 double pumper or something on it
thats crazy, interesting to hear what that would sound like..
... shit...
lol
feed it triple trumpeted webbers or even SU's and it would be allright though
Wouldnt be hard to custom make a manifold, would be better to start fresh, and make a short runner manifold feeding diectly to carbies instead of modifying the dirty 30 manifold to suit a 25
Edited by SKiT_R31
The question would be, WHY?
Even if transplanting, the engine is still from a "new" vehicle, and hence, when being engineered, needs to meet the Emmision levels of the engine.
Hence, going Carby, you will not meet these emissions, so I'd really have to ask WHY you want to do it?
If you get a whole loom, plus ECU, it really is only around 5 or so wires you need to modify to make it all fit. Much easier the customising manifolds.
Completely remove ECU and wiring harness...
but replace with custom inlet manifold and multiple carbies, you'd also need to use a different fuel pump as the EFI pump will have too much pressure for the carbies?
Potentially, yes it could be done, but question remains why you'd want to when you could get better tunability, resulting in more power and probably less fuel consumption, not to mention safe guards of things like knock sensors.
If you want induction noise, throttle response and better breathe-ability, you could make a custom inlet with individual throttles but still retain fuel injection.
induction noise, throttle response and better breathe-ability having 6 throttle bodies and no plenum if you were to use 3 side draught webbers, dellotos or so on.
Make a custom throttle with ITB, with individual air filters.
Same throttle response, same induction noise, no plenum, better tuneability, more reliable and consistent through varying weather patterns.
I still need to ask why you want to remove the ECU, considering, placing it in any car in NSW would make it illegal with ECU etc removed.
last time i checked, running an aftermarket ecu was also illegal.....
I would much prefer ITB's + MAP, but i can see why you would want carbies... and the induction/exhaust noise would be different, and you cant say for sure that you would get more power out of EFI, maybe economy and drivability and flexibility (weather, atmosphere etc) but it can be cheaper and a whole lot easier with carbies. Esp if you were to have some rediculous cam setup, aswell as other modifications, where you would need a damn good tuner to get good power (and lets face it, its hard to get a tuner so passionate to sqeeze every last kw out of a car by spending hours dicking with injector timing etc.)
Edited by SKiT_R31
It says he's from Japan so our laws won't mean anything to him LOL
Edited by MintR33
when i run modifird production in speedway the rules said we had to use a 350 holley altho it could be converted to run methanol.
a few of the guys running vl's at the time used the nissan patrol manifold with a methanol holley and made good power out of them .
problem was finding the manifolds it was a problem back then and prob even worse now
cheers mid life crisis
Thanks! :D
What's going to tell the "modified ignition system" to fire the spark?
The ECU does more than simply "control ignition timing".
If you are after the carby induction sound, you can run injectors in a weber-style manifold fitted with trumpets (have a look on www.efihardware.com). That way, you get the fuel efficiency of EFI with the induction "roar" of Webers.
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
