Just Jap Racing Gives An R35 Gtr The Chop - Literally
Hi guys,
Just Jap Racing rocked the boat by taking the first R35 GTR to enter Australia and painting it Pink, and now, its time for some more controversy to keep you all entertained!
I am currently in Japan with our in-house mechanic Gary and we have just finished chopping up one lovely Silver R35 GTR with a mere 4,000 Km's on the clock to use as a spare parts donor for our Donut King R35 GTR Race Car Team.
I hope you are all sitting down :P
Gary will chop anything
Ever imagined an R35 GTR convertible?
R35 GTR Chop Chop - Snippet 1
R35 GTR Chop Chop - Snippet 2
All in a days work :laugh:
Cheers,
Steve
  • Replies 41
An R35 GTR convertible would look great I reckon :laugh:
DOOO EEET!
also... where the hell was the damage?? it's not in the engine bay is it?? :P that isn't... that OTHER R35 is it?
Nice find fellas. So where was it damaged originally? Roof?
lol...
*choppety chop chop*
"hey you did remember that the gearbox is in the back right?"
"what?"
"rear mounted gearbox"
"in this?"
"yeah"
*clang*
"shit"
this is pete's new car i'm guessing???
heard about it on the weekend...is the chop so it's easier to transport or does it have to be done to bring it into the country or what???
funky...if it is the one im thinking off...which im guessing it is...it was side swiped. but i may be wrong...
The car is being bought in for spare parts for the Donut King Race Team, in case you missed it in the first post
Remembering of course that Nissan Oz "won't be servicing any grey imports" it's not such a silly ideal if you have the cash to do it. It also means other Grey Imports know who to call should they run into troubles.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
