I have not lost any power with blocking the bov in fact it feels better off gear changes and the same goes for putting a pod over the stock airbox
Your pod is unshielded?
If so I guarentee lower power for you.
Unfortunately, actual results are things not 'felt' but, measured.
Get a heat shield on and it should sort it out though. Blocking the stock BOV is the ultimate " look at me" rice-ness all the same.
This is pressurised air trying to go somewhere, boosted air you now don't require because you have backed off/slowed down quickly. The thought is that this air slows your spool up time when you plant the foot again. It might sound faster, but thats about all it is......sound.
And don't forget the damage... ...turbo going backwards = bad...
Mmm you would think that its bad for it, however there is no definitive evidence of damage (none that i know of anyway).
Lots of damage done is to your social image however.
How dare you stipulate my meaning based on my vagueness!!!... ;) ...Hahaha... ...Social damage is a given...
One theory I've heard is that because the front side and back side of the turbo turn as one... ...any backwards spinning of the turbo would also stop exhaust gasses from being removed from the cylinders... ...Causing bad detonation... ...and then loss of power...
As for physical damage... ...the stress on the turbo's internals may be minor... ...but over time something could break...
Either way... ...I think it is making the turbo lag greater... ...even if it doesn't feel like it...
Placebo effect???...
ahah social damage? u mean it will lift it everyone luvs it went they hear STUTUTUTUUTUT. I dont think it does any damage with the amount of boost running but even if it did so what it would prob take 10000 kms off my turbo life and thats a price i would pay to have a STUTUT but thats just me as i said some love it some hate it
  • 1 year later...
while were on the topic, where can i get a stock plumb back BOV? i have a 'turbosmart plumb back' & really not a fan of the sound, i want to be able to change gears & not be looked at by every person walking there dog. there hard to find i looked on ebay, nothing.. my 'turbosmart plumb back' is set up on the turbo side pipe from the intercooler, has a round hole where it slides on & a nipple with a tube running off it where the air gets released back into the system, can i put a stock BOV on there replacing it or would i have to do a bit of modifying? here is a pic..
http://viewmorepics.myspace.com/index.cfm?...imageID=3010801
i'll be selling the 'turbosmart BOV' as well so if anyones keen PM me >_<
Edited by azzafreddy
it does not spin backwards
the physics do not support the compressor or exhaust wheel or both spinning backwards with a blocked bov
the noise comes from a mid air collision of pressure that occurs in the pipework
its called compressor surge as the pressure spikes well past what the compressor can supply when the throttle body is closed and there is no BOV (or its blocked)
the excessive pressure makes the wierd chop chop tuutututu noise and places stress on the compressor wheel
If you have a a stock car and stock airbox. You can't really hear the bov, what if you have a POD in an enclosed box? Does it muffle the sound just as much as the stock airbox?
no, just as loud.
Hey mate... I've got a 1995 R33 GTS-T... I aint sure if i have a problem with my BOV... Usually when i rev up my engine and release it the valve opens fully and u hear the BOV go off at full.. But for the same rev it does not now... I also noticed that the cylinder tat moves n releases the pressure does not move much... Is somethin wrong with the blowoff...???
There is obviously a market for someone to make a cd with sucky induction noise and noisy bov sound for those who are that way inclined to amuse themselves without detriment to the car's performance.
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
