As the title suggests, I'm after some suggestions on buying a new car meeting the following criteria
Must be from a dealership, no older than 5 years, anything up to $40k and the preferences are:
1.Audi
2.Saab
3.Merc
4.BMW
5.Other suggestions
Pretty much in that order. So throw up suggestions/photos of some of the nicer looking models in that price range :O
Cheers
Dez
https://www.sau.com.au/forums/topic/246889-choosing-a-car/
new or secound hand? 40 grand wont get a new coupe but will get something like a e46 328 coupe or even a e36 m3
new or second hand doesn't matter, as long as its not over $40k, and is from a dealership...obviously the newer the better, but obviously with a limit of $40k the newer you go the further down the ladder you get as far as models go
https://www.sau.com.au/forums/topic/246889-choosing-a-car/#findComment-4291053
Hey Mate,
I know these differ from your list, but id look at these personally. Just to be different
Lexus
http://www.carsales.com.au/used-cars/deale...&__Qpb=true
300C (pimp style lol)
https://www.sau.com.au/forums/topic/246889-choosing-a-car/#findComment-4291304
Honda Accord Euro.
Go drive one - you'll be impressed at how nice they are.
Otherwsie a Golf GTi
Saw a Golf GTi tonight and thought it might fit into the crieteria actually...what are they going for new/2nd hand ?
This isn't for me by the way, it's for my brother with this job he's just landed...
I'm also suggesting an F6 Typhoon....Not sure what they're going for 2nd hand (BA/BF) but if they can be had for under $40k in good condition, one of those in black, with the black wheels, they do it for me nicely...
I just don't think $40k is enough to get one of the nice (what I deem nice anyway) Euros like the Mercs/Beamers etc...and Saabs dont really do anything for me..
https://www.sau.com.au/forums/topic/246889-choosing-a-car/#findComment-4291445
yep F6 typhoon - def vouch for that! one of the sales rep at our work has one - minor mods and tune, its making 350+rwkw - such an awesome car!!!! and good if your bro has a family or has a lot of drunken friends - lots of space.
https://www.sau.com.au/forums/topic/246889-choosing-a-car/#findComment-4291496
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
