  • Replies 170
Hey Mate, do the Alcon's fit behind the RPF1's ok? I'm looking at a set of the Alcon's myself but was told TE37's are the go - I would rather run RPF1's as they are a bit cheaper!
I'll have to let you know when the calipers turn up mate. I am told that the set up I have will fit behind Stock r34 GTR wheels so I'm hoping they fit behind the Enkie wheels. It's gonna be touch and go but I will update with some pics when I get them bolted on the car. The callipers are still being used but should be here soon.
I'll also need to get some braided lines made up unless anybody knows where I can get something pre made. Actually might check that out with the PWR boys when I get the pads.
Thanks for the comment. It's slowly coming together.
If you look in my sig picture the wheels fitted in that are Rays Ce28s 18 10.5 +22. They are a perfect fit and don't scrub. But, They were only 265 35 18 tyres and I would be sure that 295s would need guard mods although I wouldn't think it would take much work. It is also on my to-do list to make 295 fit under there. All in time.
Hey Roy. I hope they all fit to because it's cost me a bucket full of cash to get this far. The lad who's CAD file I got copied said that the hats and radial mounts were designed to fit inside a 34 rim and also leave enough room for the roll center correction on Ikea LCAs. We will see! Worst case is I'll have to bring forward buying a set of TE37s.
I got a call from the guys i'm getting the callipers off on friday to say they were on the way so should see them this comming week. Stay tuned and I'll post up the pics.
hey coop,
great build, looking forward to the future updates and good on ya for sticking with it. The in car footage was a treat to watch except for the crash of course. keep up the good work
Cale
  • 3 weeks later...
Callipers finally turned up. I dummy fitted them up to check the wheel fitment and had some luck. The enkei's fit....just.
I still need to get pads, lines, some bolts and then a new set of tyres for the 18s befor I can try them out.
Rim size is 18x9.5 +15 mate.
I talked to racer industries today about pads. They said they could do me a decent deal on a set of project Mu V8 supercar pads that were old stock for 500 bucks. Is this a good deal or should I be doing some more ringing around? I've already talked to PWR and they basicly said to talk to the RI guys as there range was better. Bareing in mind that I want a pad that won't take till 400+ degrees to start working as I primarly use the car for sprints and hill climbs.
looks great mate. yeah front diff is a big change hey?! but so much more traction is unbelievable. great on circuit but does need a bit of a different driving style. well worth it though. new brakes look awesome too.
  • 3 weeks later...
I have a break fettish, that looks so sexy. Such a snug fit.. what did the clearance end up being? enough for a small rock to slip through i hope :P
Brake specs? 350mm ++ ?
Edited by Willis
Probably only a couple of millimetres in places but it's enough. The calipers have stone damage a bit anyway so I'm no too stressed.
The rotor size are 375mm od and 36mm thick and have 72 cooling vanes rather than the stock alcon kit for skylines that only have 48 I belive.
Beer Baron
Posted 01 June 2011 - 05:00 PM
Thanks for the feed back Mr Baron. I am starting too work out the new diffs on the track. had some awesome results with them at the last hillclimb. Really happy with them.
Edited by Evocoop
  • 3 weeks later...
Looking good Coop, have you had the Alcons out for a race meeting yet?
What size brake master cylinders did you end up with?
Nah not yet. Too broke to put new tyres on my 18s and they don't fit under the 17s. Hopefully next pay I should have them in and get the braided lines made up. I got a new set of project Mu pads for them from Racer industries while the V8s were in town so nearly ready to go. I have a 33 GTr Master to go in. I'll just see what sort of pedal it has and go from there.
Loves the E85. Maxing the 1000cc injectors at about 430rwkw but wound it back a bit untill I can afford some 1500s.
Got half a second quicker at the last sprint round so still getting better and heading in the right direction.
  • 1 month later...
Quick update about the new brake upgrade. It's working really well and has very solid pedal and a good bias. The r33 master seems to be perfect. My only complaint is that the booster is making it a little hard to modulate. I have a plan to kick it to the curb and re mount the piviot point of the pedal to compensate. Something is working though as I broke our local tracks lap record at the last sprint round. Could also be bigger rubber. I'm now runnning Federal FZ201s in 265 35 18s all round.
Well it's off to Lakeside raceway this weekend for a sprint day and I've also nominated for the Japanese Nationals the following weekend. Don't have too many expectations for the Lakside trip as it's the first track I've been on that 5th will see some use so there will be no heroics there. Somewhere under the Magic minute would be nice though. Other than that It'll just be nice to take a week off work and tow the away from the little stuff in Townsville and take it somewhere it can stretch its legs. Been a long time to get it there.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
