Well, I'm off defect. Spotted tx3_90 while I was there.
ahh so that was you, hai!
yeh i got through as well... was my second inspection $68 and 5min of checking i fixed everything on the list.
funnily enough as i was driving out i remembered that the boost controller was still hooked up in the engine bay (had 72hrs after first inspection so put it on for a bit of fun) but he didn't check. :D
back to saving up for a paint job.
cock of shit! they'll still find something if they wanted to
Yeah you're right. Neil pulled up my skyline which is pretty much standard (on the outside, anyway!).
It's a black 4-door with after market mag wheels. That's all. It's not lowered, no body kit, standard exhaust system...but has the worst thing of all...A skyline badge.
And hence the reason for my defect. :D
there is always something you can get done for but that was his main concern. i would rather sell my car rather than go through regency
Which, according to Neil, is exactly what he WANTS! He told us when he pulled us over and defected our skyline that it was his aim "to convince Skyline drivers to sell their cars".
Our response was "And sell them to who, Neil? Teenage hoons who will actually do something illegal in them?"
To which he had no reply.
:D
:D
ouch
was something like $137...
you sit down at a chair just infront of the car
First thing he does is check all indicators/lights, seat belts, pop the boot+bonnet etc
The guy hardly looked in the engine bay - looked completely standard for him to bother I guess.
He spent the most time under the car - hoisted the car up and went straight to the rear where the hicas is and looked around there, looked at the bushings and components around each wheel, he then jacked the front up and had a crow bar looking thing pushing the wheel up - may of been testing the shocks? or bearings?
No exhaust decibel check - was quiet enough.
Did a brake test for front and rear - sigh of relief when the word PASS went up on the screen lol
After all that he just mentioned the passenger seat was moving about a smidge - need to tighten a bolt down or something, but apart from that everythings good. He removes sticker, signed it off and away I go.
All up from arriving to the front office to exit took no more than 30 minutes.
Yeah this sounds about right. Got my defect off first time too on the 12th January. I sent the missus in with the car because I am known for my temper if the inspector started being an asshole, but it was all good. Everything passed...
...except my window tinting on the front driver and passenger windows, which I had to strip off with a razor blade infront of him before he would sign the release form.
Guy who did it was nice though, he thought any copper who targeted skylines was a bit 'wanky'.
Tint-a-car fitted me in that afternoon too. All in all, not that bad! :D
:P
lol just what i was thinking, hey good idea, get everyone with experience driving imports to sell them to people without experience driving imports, that makes sense lol
i know i wont sell my car because of defects, it will because of crashing it if anything, so using niels logic police should encourage us to go as hard as possible so we crash and get rid of our cars.
They might start pulling us over like they do in the US...by rear ending us with a cop car...
And hence the reason for my defect. :P
So you were defected for a badge? ;)
Tell us then ... what were you defected for? What do you mean by "pretty much standard"?
Edited by RubyRS4
And hence the reason for my defect. ;)
hrmm your skyline wouldnt have happened to be parked in a shopping centre car park on main north road on friday?? i saw a skyline exactly how you describe yours but this r33 wasnt defected...
Yeah..standard on the OUTSIDE...he told me he pulled me over because it was a Skyline. No other reason.
However, under the hood I was busted for turbo timer, boost controller and BOV. Oh, and gauges up the A-pillar.
Fixed it all and passed first time at Regency last week!
hey guys,
I was pulled over a bit back near marion shopping center, the deal was, reved out 2nd into the corner to get the orange turning light and got a fine for excess noise pollution?!? $133 for that. Formal corsion on pod being loose/not secure, but the coppa was looking 4 the tyre placard. car has had a respray and aint there?
In regards to the wheel diameter measurment, 16'' is standard on the placard 4 a 32 but mine has been painted over how would i go about getting a replacement?
cheers
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
