I havent called around yet, but there was a certain owner at autosalon of a 400kw R33 who had his seats engineered aswell as coilovers and adjustable arms. Think it might of been Rory Thompson.
Bride seats can be Engineered. I may be going down this track later on. :)
from my research just about any seat can be ADR engineered , they're is a engineer guy in lonsdale who signs off on them for a price but regency can still pull out the defect card even with a engineers certificate ?
anyone know of a lower seat rail for R34 GTT, everyone I call doesnt carry them anymore ????
found some seats but doubt they're ADR ... tired of farking SA rules ... different then ADR
has here has gone thru regency with a CF bonnet and passed, Helso ???? anyone ??? where can you buy a legalish one???
pretty sick of having to know whats legal or not and 10 different answers from regency people. if its not legal dont sell it to the public for use on the street
on the 31 club forum...there was a cop that signed onto the forums for a while...and got swamped with " whats legal" questions and what not...then a mate of his that was a regency inspector signed up and was able to answer all of those questions posted...he was a massive help for a while until he kept on getting swamped by the same questions over and over again...
Mallala cop? He was on ns.com for ages.
Now he's dissapeared?
Rory Thompson did my 1600. Was great to talk to and very helpful in all areas of modification and ADRs.
Yeah got a quote from Rory yesterday to engineer my upper rear adjustable control arms... thinking I might hold of until I've gotten adjustable toe rods, and front camber/castor rods, then get the whole lot certified at the same time
-D
A place to report your defect, where you were defected and discuss defect related mods.
Keep it clean with no slagging. If your defected out and about legitimately take it on the chin. :P
On the other hand if your defected for an item which is standard (i.e the factory bov) let us know. But keep it clean.
Info Bulletin 3 - General ADR Guidelines
Info Bulletin 44 - Vehicle Ride Heights
i got yellowed for a crack on the bottom lip of my front bumper...
now it was a crack all the way threw but the front bar wasnt going anywhere... im a panel beater so trust me u could kick it and it wouldnt go anywhere
DEFIANTLY DUE TO ME 'RED' P PLATE???
did you get sent to regency? what is written on the defect notice / ie "damaged front bumper", or is there more to it?
probably coz he was dodgy... i looked up his badge number and its from some cop in pt augusta... not even a traffic cop...
theres another cop on ns that used to have r32 - sl33per or something like that... i could defect his r32 just by looking at his avatar (tinted headlights, ride height, offset...), so...
you mean ryan
lol
he aint been a cop for long, but he's been round the car scene for longer than you've had cooked dinners my friend ;0
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
    • I can donate $100 to your upgrade fund. So long as you can donate the IC7 my way....
    • I'd love a Haltech ECU, and Haltech 10 dash. Was having a chat with Rob and Andy @ Haltech when Rob put one in his MR2. First one I'm kind of interested in too, as you can dim it RIGHT down. Andy was saying bright dashes is one of his peeves too!
