This is easy to answer, it is illegal to have a venting battery inside the car unless it is vented to the outside.
You either have to buy a battery that has provisions to attach a tube that can vent to the outside of the car, through one of the bungs in the bottom of the spare wheel well.
Or
Buy a fully enclosed battery that does not vent, such as an optima. Carbon34 may know of more batteries you can use.
I believe you can also enclose the battery with a case and have that venting to the outside.
What battery do you currently have?
Just checked the battery out for you, and unfortunately it will not pass.
You will need a AGM or dry cell battery like i mentioned earlier, Optima or Odessy.
Unless it has ventilation holes in it.
I have to second this - the Optima batteries in particular are awesome. I've had the same one for 4 years and it still doesnt miss a beat - even after multiple discharges to zero volts
-D
They are on the slightly expensive side, however they are well worth it.
Unless you like rust i wouldn't recommend anything else, especially after what my century did to the back of my car. Thankfully it cleaned up fine.
Yea a marine battery is similar to what i have mentioned, i am certain all of the Optima Batteries are fully sealed and do not ventilate.
Just change the terminals on the cables that you have so that you can take the regular sized ones instead of the shitty small Japanese ones.
Edited by Grimesy
I'm in the same boat, HICAS hasn't given me any issues so I've left it as is.
If you don't track/drift 90% of the time imo having it is better, nice turning circle and means you can smash roundabouts at 60, providing of course your bushes aren't screwed, then it can feel a bit sloppy.
  • 2 months later...
Im surprised at Regency they dont check for straight through cats considering how many people have them and the fine for not having a cat is huge! All they would need to do is send a flexible cord through the rear exhaust and if it goes straight through the cat...then busted.. Hopefully they dont tho
still no one is stupid to go over the pits with a bashed out stock cat either
what if the brought the car and didnt even know about it. Thats what im saying i dont even think regency check it which youd think they would
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
