This is easy to answer, it is illegal to have a venting battery inside the car unless it is vented to the outside.
You either have to buy a battery that has provisions to attach a tube that can vent to the outside of the car, through one of the bungs in the bottom of the spare wheel well.
Or
Buy a fully enclosed battery that does not vent, such as an optima. Carbon34 may know of more batteries you can use.
I believe you can also enclose the battery with a case and have that venting to the outside.
What battery do you currently have?
Just checked the battery out for you, and unfortunately it will not pass.
You will need a AGM or dry cell battery like i mentioned earlier, Optima or Odessy.
Unless it has ventilation holes in it.
I have to second this - the Optima batteries in particular are awesome. I've had the same one for 4 years and it still doesnt miss a beat - even after multiple discharges to zero volts
-D
They are on the slightly expensive side, however they are well worth it.
Unless you like rust i wouldn't recommend anything else, especially after what my century did to the back of my car. Thankfully it cleaned up fine.
Yea a marine battery is similar to what i have mentioned, i am certain all of the Optima Batteries are fully sealed and do not ventilate.
Just change the terminals on the cables that you have so that you can take the regular sized ones instead of the shitty small Japanese ones.
Edited by Grimesy
I'm in the same boat, HICAS hasn't given me any issues so I've left it as is.
If you don't track/drift 90% of the time imo having it is better, nice turning circle and means you can smash roundabouts at 60, providing of course your bushes aren't screwed, then it can feel a bit sloppy.
  • 2 months later...
Im surprised at Regency they dont check for straight through cats considering how many people have them and the fine for not having a cat is huge! All they would need to do is send a flexible cord through the rear exhaust and if it goes straight through the cat...then busted.. Hopefully they dont tho
still no one is stupid to go over the pits with a bashed out stock cat either
what if the brought the car and didnt even know about it. Thats what im saying i dont even think regency check it which youd think they would
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
