The Caltex and BP on the Princes Hwy at Tempe are always the lowest ive seen.
Caltex was 91.5c for E10
BP was $1.08 for Ultimate
It was 89.9 @ Narrabeen SHELL 2nite...
But that was with a docket...
Filled up with V-Power @ 108.9c
why the hell is newcastle's lowest price we are seeing is 98.9 for normal unleaded but i am cheering about the price drop it used to cost me $90 a week to get 330km out of my fairmont 5L now i am filling up in the skyline for $45 score
Shell is ripping us off 3c a litre (50L x 3c= $1.50 = half a can of red bull... 2 fill ups later we can afford a can) LOL pulp 98 is meant to only be 10c higher than regular ulp shell Is 13c more and bp is like sometimes 16c and higher more so go caltex or mobil to rebel (you see I used to work in the industry and anyway caltex sells pulp to everyone except mobil which makes it's own so it doesn't make a difference except to our pockets), where's everyone getting boost 98 from??? I've seen good dyno runs on that
Edited by DaGr81
^^^ Exactly. Still feels like we are getting ripped, just in a different way. Anyone know why the difference became 13c at all pumps(one's I've been to anyway) Caltex, BP and Shell all started doing this once the prices started heading down. What would be the justification?
Not sure myself but just some caltex is ripping us , mobil ftw! Bp seems to always have been doing this though, although they use the same barrel of crude oil to produce 92, 96 and 98 funny isn't it.... Should we complain to the consumer watch dog? As a group ?? I want that red bull dammit
  • 5 months later...
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
