You may need your aircon system converted from R12 gas (now illegal) to R134A (new gas) which can cost quite a bit.
It depends on where you are in Canberra as to which shop to recommend, there are lots of good shops around that can do air con.
yeh battery terminal couldnt do it till next week. Wanted it done before i hit the coast tomorrow arvo....
im getting it done at lonsdale auto electrics (lae) close to work.
Hoping its just a regass not a conversion otherwise i'll wait till i go up to sydney and get it done up there...... stuff paying 500 for a conversion.....
there is a direct drop in for r12 its called R49 or R409 both will do the job if done by someone who has a clue, also 134a can be replaced but will more then likely cause seals to go in the compressor, oil and dryer will need replacing as well.
Talking to someone who got a 30 year old fridge freezer to run on 134a lol... lasted 12 months sooo should have put more oil in.
The whole Conversion doesn't cost bugger all if you know what you are doing
R12 to R134a adapters from Ashdowns in fyshwick cost you around $20-30 or cheaper
and a New receiver dryer unit costs around $60 or less I think they are alot less but I cant remember ...
Just have to get someone to decant the old R12 gas out for you ...
Then I wouldn't go with R134a at all I would go the the even newer gas ...
Hychill which is pretty much an LPG style Hydrocarbon refrigerant and you dont have to modify anything to convert to this gas
it is cheaper to regass and the air inside the car gets alot cooler and the compressor is 30% more efficient doesnt have to work as hard ...
And you can release it to the atmosphere and you then dont need an Aircon liscence to regass you own system ...
  • 1 month later...
Yeah R134a is Absolute Shit !!! Sure it may work ok when you are on a motorway doing 100+ for a good 15 or more minutes. But around the city the car feels like 2 pistons were removed and I can blow cooler air out of my Butt. I have yet to see the car that has been converted to R134a that runs nice and cool in traffic...Need to learn more about this Hychill stuff however.The bullshit stories i hear from Auto electricians amazes me. Stuff like the car can explode if a cigarette is lit in the car, to it keeps your compressor working much more often and then stuffs it. That and it is supposedly dry and stuffs the compressor.. Why they just dont admit it " I have no F*cking idea how Hychill is "
Edited by GTR-32U
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
