Ohhhhh, nice. Brilliant. R34GTR rims and all. That's awesome. Pity boot glass has been replaced with non-UV cut glass. Pity is series 1. But it's got an RB26 and a strong driveline... bring on the 300+AWKW :spank:
Congrats ,very nice...excellent body kit and I WANT YOUR MIRRORS!!!! I love how they look,very agressive front .Is the fmic pipping painted yellow?Welcome to the stag world... :spank:
wll done pal smart look'in 260 hope you get lot's of enjoyment out of it, and by the way nothing at all wrong with s1's a lot of people prefer the look of s1's over s2's
have fun.
Thanks for the kind words guys. The last thing I needed was someone saying my new ride looked like crap. :whoops:
RBPOWA
Abflug front bar? I honestly have no idea what the kit is. The rear window is tinted, but I think its an aftermarket tint.
GoldZilla
Nah mate, Victoria :yucky:
southern_tango
Yes I love the mirrors , I've removed this today as its going to compliance sometime next week.
mitchy_
Yeah I think the no rails look is best for the 260
leetom
I had to choice of a series 2, but chose the series one. Just something about it, l find it more of an aggressive look.
The car came with an N1 engine and N1 turbo's. A really nice remote oil cooler, HKS exhaust, HKS cams and cam gears, Tien shocks, HKS Pods, HKS dump pipes - I think whoever owned it in Japan really liked HKS :)
Just about everything has been removed today for complaince. Once thats done and its rego'd, I've got a set of gold DBA slotted and crossdrilled disks to go on it and a bunch of other stuff I've had sitting in the garage waiting for its arrival. Cant wait to finally have it on the road.
Cheers.
  • 4 weeks later...
Got the 260RS in the workshop ATM. Finally rego'd and road legal. Now the fun begins :D
Had a set of Tomei cams and cam gears installed yesterday. Also sprayed the engine with black wrinkle paint. Today a set of gold DBA slotted and cross drilled discs will go on (will take a pic when its completed) then the power FC and a bunch of other stuff.
Will post work as its done, sort of a build archive for anyone who's interested.
Cheers.
Edit: oops there's also a new water pump and radiator, though you can just see the new water pump in the pic.
Edited by GTR91
awesome
how are the cams? sound horn?
awaiting mine back from the tuners, might call em see whats up
:D
need 2 hear it :)1
They sound secks with a decat. Mine sounds like a rotor sometimes.
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
