Gday crew was playin with my car had the front bar off and noticed this. It looks like something to reduce intake noise some sort of plenum to stop surging noise out of the stock air box like falcon xr turbos have on the side of there intake. thing is i no longer run an air box just my pods. is there any point me having this gear in here still? or is it just wasting space?
In the pics you can see my set up and where the stock air box would hook up to the vent below the headlight, drop down under the car and into the box that is completely sealed actually has no opening aside from the pipe.
Anyone got info on exactly what it does and weather i need it now or not.
thanks crew
Dion
https://www.sau.com.au/forums/topic/248468-32-gtr-standard-air-intake/
i pulled the box and connecting brackets off. then did a 180 with the elbow pipe so that it could collect some cold air from the front bar vent. From memory i did some cutting/reshaping of the end of the elbow to aid air entry.
yeah sounds like a plan. nothin like a cheap cold air intake!
Pretty sure the gear is for noise suppression for the BOVs (look at where the air channel runs to the drivers side and follow it along). They're still quiet enough with it removed. I run the stock airbox and have removed it to help with airflow.
Like teh Baron says it is a resonator.
But do yourself a favour. Use the remaining pipework to help get some cold air to the pods.
Works like this:
Beneath the headlight there is the air inlet which used to feed the stock air box. The resonator is connected underneath it.
Use this connection to grab some air fron the front left hand side of the front bar.
That way when you get sick of your pods sucking hot air from the engine bay you will have a ready source of cold, pressurised air. :(
Works like this:
That way when you get sick of your pods sucking hot air from the engine bay you will have a ready source of cold, pressurised air. :)
im down like a frown with a clown! its like nissan said "hey we will put this silly box here to get rid of some lame noise but when people with pods come along they can turn it into a cold air intake, we are so crever!"
oh yeah :D
thanks crew
Dion
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
