What do you guys think is better a 970 black edition or a 970 wind force ?
Apart from clockspeeds (usually isn't much to be honest) and the styling they will be the same. There isn't really much that distances the same cards today. They are both good so get whichever is the best deal.
  • 3 weeks later...
I will probably only have windows on the ssd and what is a good price for a 3.5 ghz i5?
Not sure but you could always look on eBay and see what kind of deal you can get. If you're in the UK you could look on Scan.co.uk which is a pretty decent site, I've got quite a few components off there and so far no issues with them.
eBay you can get decent parts if you're willing to look around. I've just bought an old EVGA GeForce GTX 460 SuperClock which cost £40 + £5 for delivery, I didn't need it but I like them so it was an impulse purchase.
My R9 280X with 3gb of DDR5 has been doing very well with modern games lately.
Few hiccups with GTA5 due to AMD, but runs 50-90fps on high-ultra settings (all the advanced graphics and distances turned off). And been running really well with project cars, maxing out everything except shadows and reflections (to keep it smooth). Also none of the issues that the 290 cards are having
Have the same card, also surprised how well it plays modern games.
Case: NZXT H440
Motherboard: Gigabyte GA-Z97-D3M
CPU & CPU Cooler: Intel i7 4790K & Corsair H100 GTX
RAM:Kingston Hyper X 8GB 1866Mhz Dual Channel
Monitor: 25inch Dell Full HD Monitor (will upgrade soon)
Graphics Card: Gainward GeForce GTX980 4GB GDDR5
HDD(s):Kingston Hyper X Fury 120GB SSD & WD Green 1TB
OS Used: Windows 8.1
Peripherals: Razor Orachi Wired/Wireless Gaming Mouse, Logitech G27, Xbox One Controller
  • 4 weeks later...
Just started to collect parts for a new build, my 5 year old PC is starting to show its age.
Starting off with a Mini ITX and a Lian Li.
I have the case, but i'm waiting for all the new lineup of GPU's to be released.
How do you guys get neat cable managements?
My case looks like a rats nest inside with explosions of cables everywhere, and my poor attempt at cable managements only made the inside 1000xs worse... :closedeyes:
Be gentle with the Corsair cooler. Also that WD Green drive, if you're doing anything more than archiving, you're gonna have a bad time.
Corsair is holding up really good at the moment as i have overclocked it to 4.2Ghz without any dramas. I will order WD Black 1TB drives, agreed the Green will cause trouble other than mass storage as its limited to 5200rpm versus the 7200rpm of Blue and Black.
Corsair 450D:
Gigabyte Z97X-SOC:
i7-4790K+H100i:
Corsair Vengeance Pro 2133 (4GBx2):
Acer 24":
Gigabyte GTX 770 2GB:
840 EVO 240GB, Seagate 4TB(s):
Windows 8.1 + OS X 10.8.2:
M65, K40, NZXT Hue:
It's overkill for the games that I play.
The WD greens are nice and quiet though. But horribly slow.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
