Found a set of 32 GTR rotors, calipers and brake lines for $800 for my na r34.
just wanting clarification that it would swap over without and modification. (except for brake lines),
Been told it would but couldnt find a definate answer before i part with the $$.
Thanks
https://www.sau.com.au/forums/topic/249797-32-gtr-brakes-on-34-gt-na/
i stuck gtt brakes on my 32 gtst
only mod needed waht that the bolts that hold onthe caliper in much bigger on the gtt so had to drill out the mount
now 32 gtr are the same size bolts as gtst and the gtt has bigger bolts
so if u have bigger holes than the bolts for the gtr calipers u might be in a little trouble
Hey mate.
Have a read of this thread... http://www.skylinesaustralia.com/forums/N-....html&st=20
If it was me I would stay with R34 brakes so you don't need new hubs etc. I have em on my 32 as well and they're awesome. Larger than 32 GTR as well. 310mm vs 296mm.
Thanks
If it all works out for the R32 brakes and you've not committed to the brakes you've found I've got a full set of R32 GTR brakes including 2 sets of pads. All in near to new / very good condition. Check this out.
http
:P/www.skylinesaustralia.com/forums/R3...s-t248527.html
Cheers.
you can use a sleave/insert which goes into the mount holes in your hub to reduce it to the right size so you can use the smaller bolts. or you can get the calipers fitted with timeserts (stainless steel threaded inserts) which will enable you to run the bigger GTT bolts. cost about $100 to have someone come out and do all 4 holes for you. rear i'm not sure on, but that's the deal with the fronts anyway.
Just buy R34 GTT brakes or go the whoel hog and get soem R34 GTR Brembos. They are the same bolt size and because of the issues Baron describes above are really only good for R34 owners. So R34 Brembo brakes often work out cheaper then R33 Brembos because you don thave to fiht every R32, R33, Silvia and 300ZX owner for them. Demand = Dollars
Ok, I have put R34 V-spec brembo's on my car and unless your car has GTT hubs they wont bolt straight on, and you will need R33 GTR brembo's.
The bolt for the r34 gtr brembo's is to big, so i had to drill the hole out to make the bolt fit. The Rears bolt up perfect. You will also need to adjust your handbrake tension as the rotor is alot bigger.
Any other questions just ask.
It only has the stock little gt brakes so i dont think it would have the GTT hubs..
How much did the set of 34GTR brakes set u back. only reason i was considerin the 32 ones is cause they were 1000 or under, dont really want to pay close to 4 grand.
Even the GTT rotors and calipers and hubs would be nice, but dont really know much about how to get a set of hubs or if they would just go straight on or not.. i assume they would though (not real good with brakes knowledge)
From this it sounds like GT's have the 12mm hole, not 14mm like the GTT's....
A full set of R34 GTR V-spec calipers, rotors, lines and pads and only used for 17000k's cost me roughly 2.5k delivered. On top of that there were braided lines $250 a set and getting the rotors slotted $133.
^^ thats right. Reason being the r34 gtr bolts are 14mm ( same as GTT). R33 GTR bolts are 12mm (same as R34 GT)
Are they Vspec R32 GTR brakes? As i was under the impression that unless it was a Vspec the 32 GTR brakes werent brembo. So why would you bother?
He has an R34 GT. Non turbo. Brakes are single piston I think. Hence the upgrader to bigger better ones with more pistons.
r34 gt na brakes are 2pot fronts, 1 pot rear, the same as na r33 brakes.
The r32 gtr, r33 gtst calipers/rotors will bolt straight up, no mods are required (which are 4pot front, 2 pot rear)
The caliper bolt size difference only applies to the turbo model r34's, the na's still run the smaller 12mm bolt which is the same as the r32 gtr and r33 gtst so these will bolt straight on.
So to answer your question, yep they will bolt on
ok, thats the kinda news i wanted to hear..
Hopefully ill be able to get the $$ in time,
otherwise ill just have to save my pennies for a bit and find another pair..
Only other concern is that will i need to get a bigger brake booster for the brakes or will my stock one do the job? (sorry if its a dumb question, just dont want to miss anything)
Thanks for all the input btw everyone, been a big help.
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
