I also need to rebuild my server - 5TB and its full. Need to go and blow a good $700 on drives, maybe more.
Love my Perc 5/i - can load up 8 drives all in RAID5 no drama and it moves files around very snappy
Yes hopefully we will be retiring some R710s with the right PERC cards soon, I want to see someone else use one IRL to see how it will perform, incidentally I have seen a RAID 5 with WD Greens drop both the parity and another disk recently, luckily the colleague who owned it was the paranoid type and didn't store any essential data on the array, but I think that I'd be using Reds or RE3 drives if I were to get off my arse and build a proper file server for home.
I don't really go for the whole soft RAID thing, at this point in time I find that 3tb is enough for me, and should I ever lose it all, I can rebuild 90 or so % from my workmates' storage pools. That said I've been tossing up on burning off onto dvd some of the more obscure movies / music that I have.
I like to try different setups with PC gear - I've done the whole two midrange cards in SLI thing, and will sooner or later step up to 1 680 as BF3 keeps locking up on me (haven't tried latest drivers yet though). Also might invest in one of the cheapie Korean monitors - they are the same panel as the imac 27 after all.
I've had greens running on the Perc 5/i for maybe 3 years now 24x7. No issues yet and there are 4 drives.
Only issue is needing a fan, can be a tad noisy unless you insulated a case or something as I'm just using old PC cases as the mounts as they have 5-6 bays each which works fine. So i really need $1400+ so i can make a back up as i have a spare Perc 5/i & 8 SAS.
I've had 2 blacks running for 4 years RAID0 as well without issue.
Guess its largely pot luck. Some have problems, some don't - just like all HDD's. There is a failure rate but its low for most.
No doubt on my next build im going to have at least 1 or 2 of the 10 drives shit themselves
Statistically speaking, I've seen the highest failure rates at work from Hitachi, Seagate, Samsung and WD Greens in that order. We have a wall lined up with dead Hitachi drives lol.
Nearly all of the dead Green's I've seen are from RAIDs though, I've heard that the power saving function built into them can cause havoc, but don't have any proof of that.
  • 4 months later...
(You should NEVER run voltages on auto when overclocking heavily. Even minor clocks manually setting things is advised as often mobo's over/under volt.)
so true, thnx heaps, no where in my hrs of reading did anyone mention not to run it at auto, ive now cranked it nicely down to 3.8ghz at 1.26v, uber stable, with icy cold temps, even in prime or OTTC or orthos im getting no more than 50 degrees
soi from what im running now, there is sooooo much room for ramping it up more, but im happy with 3.8ghz,thats what i was looking for in the first place.
on auto voltage it was always running 1.55v even at only 3.4ghz
so heres the finished product, let me know what you think
E8500 3.16ghz (stock)
clocked to 3.8ghz 400fsb x 9.5 (standard multiplier)
Vcore 1.264 (CPU-Z) 1.30625v (bios)
idles at 29-30 degrees
full load stress test 47-50 degrees
Since doing all this i did a reinstall a while ago, and never bothered OCing it again. So tonight i was bored and decided to give the old rig a bit of a boost and put all these numbers and settings back in.
So all runs well, temps are good, its stable under stress tests......but windows refuses to recognise my network card while its overclocked. I havent touched any PCI frequencies or volts
Back to stock it goes till i can figure this out.
  • 6 months later...
I'm in the market soon for a new SSD to run my OS. I've been running an OCZ 64gb one at the moment I picked up just as they were becoming more affordable and suffered some issues before doing a firmware update, but since then I need to reimage the system every year or so as lock-ups and failures to boot get too often to be usable. (im pretty sure the SSD is to blame, not 100% sure though)
Need to upgrade graphics card as well, GTX465's are too uncommon to SLI so will get a new one. Looking at GTX760's and a supporter of EVGA so been looking at: http://www.scorptec.com.au/computer/50789-02g-p4-2765-kr
Also want to get a new monitor (not a tv), preferably more than 100hz and 20-24" 1920x1080.
Anyone recommend any brand or products?
running an i7 920 that rarely gets a work-out with 6GB DDR3 of corsair memory
I've used quite a few Samsungs, OCZs, Corsairs and Sandisks in the PCs at work and at home (I have an OCZ (120gb), Samsung (250gb) and Corsair (60gb) in my home PC)
I've also rolled out about 20 sammy and sandisks at work.
The Corsair let me down about 2 weeks after I bought it, however it was an early one ($180 for 69gb - had it about 2.5 years). The OCZ has given me trouble not wanting to be detected by my mobo. The sammys and sandisks have been flawless thus far.
Most SSDs these days are fine although the Samsung, Sandisk, Crucial and Intel ones seem to be slightly better, reliability wise. Speed wise they are much of a muchness.
https://www.centrecom.com.au/samsung-840-250gb-mz-7td250bw-25-ssd - that's some good buying.
The OCZ Agility have had major issues, the current generation I'm not sure about but the previous 2-3 have all had problems.
I'm currently running an old OCZ as well in my Lappie, will change it shortly as all sorts of weird shit keeps happening with blue screens, windows failed to load etc - And it's all started since i put the bloody thing in 8 months ago. Was fine before that :(
Mate had the same issues with his Agility as well, almost identical...
Samsung / Sandisk definitely a good buy.
Have Sandisk's that have run fine for 18 months, on 24x7 on a PC... Only thing I notice with them is after long periods of inactivity (say, overnight)... Sometimes it takes 2-3 seconds for the drive to realise I'm exploring it when I go to use it the next day. Not really something that bothers me, just something I've noticed.
  • 11 months later...
What's the current decently priced graphics card people recommand?
Thinking of upgrading my aging Geforce 570GTX as I found it can no longer maintain stable frame rate on recent new-ish games (such as watch dog).
I'll only be gaming on a single 16:10 mointor (1680*1050), however I would like to run with graphic setting set close to max and I would like the ability to run 3 of these monitors from a single card (some thing my current GPU can't do) in the near future. Currently I'm running two of these mointors.
Rest of my system consist of Intel i7-2600K, Asus Z68 mobo, 8GB ram, whichI believe don't really need upgrading at the moment for gaming improvements.
I'm an nvidia fan. but best budget / bang for buck a radeon r9 290 the way to go for best performance / cost these days.
nvidia gtx 770 another good mid-higher end card / cost (you can always over clock these more than ATI cards as they run cooler) but yeah the 290 is a decent card for the price at the moment.
edit: if you do go ati 290 series card make sure you get one with a decent cooler (gigabyte etc) the standard 'reference' coolers are LOUD on them.
Edited by UNR33L
picked up a set of AudioEngine 5+ speakers this week. really happy with them. bit bulky, but much better than monitors + amp or having to check a sub somewhere. recommend.
up top is very clear and crisp. bass is heavy but ive turned it down via equaliser.
  • 3 months later...
& looks like another WD green drive is about to die... f**king these must be the biggest unreliable POS ever made. Looks like simply loading up bittorrent is enough to wear the POS out fast enough to die within a year of 'moderate' usage.
My old Samsung 7.2k rpm drive which I carried over from the old Intel Core 2 era (5+ years) is still working flawlessly mean while 2 of these f**king useless garabage all kicked the bucket in about 2-3 years.
Now the issue is what drive should I get to replace these useless paper weights, maybe the WD blacks or Segate 'normal' 7.2k drives are better?
My NAS is running 3x WD 3TB red drives atm, these current experience with WD isn't giving me much confidence.
/rant
EDIT: I still got 2 more of these green drives left, lets see how long these f**kers can last...
Edited by Mayuri Krab
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
