about 3000km ago i recently changed the gearbox oil to redline lightweight shock proof (smurfs blood) in my r33 turbz. i started to get a bit of fluid coming out of the breather valve, i'm pretty sure. so i ran a rubber hose to the top of the engine bay. its been a while and i'm still getting a little bit of fluid coming out of the hose and onto the engine bay.
the bolt on the side of the gear box has been taken off, and got the correct amount of oil in it. and nothing extra came out of the breather valve.
approx close to the full bottle of fluid went in, about 3.5L i think and was poured in through the shifter inlet, inside the car.
Now anyone got a simular problem? any advice.
i want to place the rubber hose somewhere else as i'm stick of taking the oil off the engine :P
however i'm trying to work out if everything is normal.
https://www.sau.com.au/forums/topic/249950-gear-box-breather/
Hmm, when I did a fluid swap with the lightweight-shockproof I had no leakages that I knew off. Maybe you over filled it? Though I recall using a full us gallon plus a touch extra to get mine to the filler hole (I filled through this with a pump bottle). I did let mine drain overnight though.
It should only leak if it's got too much I'd of thought but I'm not an expert. We're talking a 5-spd manual right?
yer its the 5 speed turbo, NOT A GTR or auto
is it ok to fill it via the shifter? because i was reading that gtr can't because of the transfercase, is that right?
I know it's fine to fill through the shifter in the GTsT but I'm not sure about the GT-R as I didn't have to swap mine when I had the GT-R, I only did it in my GTsT.
Only thing I could think of would be overfilling but if you said you'd checked the filler hole and it was fine yeah?
open up the filler plug and see if anything comes out. if oil comes out, you over filled it. from time to time they will throw out oil during hard driving, usually only happens on the track though. you can lengthen the breather, or other solution i've seen on track cars is to make a little expansion tank at the end of the breather. so the breather feeds into a vented tank which then allows the oil to drain back down into the box. but on a road car you shouldn't be having the problem. the other less happy answer is that something is wrong with the box, but it's more commonly just too much oil.
yes GTR cannot be filled via the shifter hole as the GTRs shifter goes into the transfer case, not into the gearbox. GTS4 is the same. GTST is fine to fill through the shifter hole, but personally i find it easier and less chance of overfilling and less chance of mess to just fill it through the filler plug as it's meant to be. :domokun:
K thanks, however has anyone had a similar problem? Cause I'm considering putting in another type of fluid but the box itself feels really good using the light weight shockproof RedLine stuff. Not sure but is there an simple explanation? Some tell me to only pour 3L in! Anyone no wat Nissan reccomend?
Mine took a whole gallon bottle and then a bit more using a pump bottle and the filler hole.
I let mine drain overnight.
Boys i gotta say a simple question like how much oil in your 5speed and only 1 response (2 in thread)
Thanks action dan :blush:
your only spose to fill it up to the filler hole on the side of the gear box, if you must fill it throught the shifter then have the filler hole open and when it starts comming out of that hole then it full,
if i was at home id look up the specs in a workshop manual for you but im not home for a few weeks
Edited by s13_Skyline_inside
  • 5 years later...
I'm having the same problem.
I had a look under the car after a long country drive to find a fair bit of blue gearbox oil at the rear of the gearbox and on the crossmember:
The car's also recently been on the dyno so it may be from that too. It's an R34 GTT with R34 RB25DET gearbox and Redline Lightweight Shockproof.
I had a better look today and it's definitely coming from the breather:
Is there meant to be a hose connected to the breather? If so, where does it connect to? This is a recent conversion so maybe this is something that's been missed in the install...
I was just trying undo the driver side 1/2" plug (refer right arrow below) on a level surface to check the oil level, can't get enough leverage, is there a good trick to this?
Thanks!!
Got the filler plug open yay. There's still oil in there but I'd estimate the level to be 2-3 mm down from the edge of the filler hole. Photo below though it's a bit hard to see.
How much oil do you reckon I need to fill it up to full? And how do I fix the breather hose so this doesn't happen again??
Cheers
Yes, breather runs up to there. Someone with small hands might be able to fit it up as per original, but it doesn't have to go there. Just get a long bit of hose and run it up behind the engine and fasten it to some convenient point.
FWIW, my breather hose runs up to the normal spot and I still get the shockproof foaming up and bleeding out of it. It does it when the car gets a flogging. So I am going to (one of these days) extend my breather hose up higher anyway.
Edited by GTSBoy
I had the same issue, i put a common clear plastic fuel filter ( for a carby engine) in the middle of the breather hose and ran the end to up behind the head (as per factory). This fixed the problem, the fuel filter acts as a oil/ air separator, and only cost a few $.
Cool I'll do that. I assume I can use any old auto hose for this?
Great idea! Do you mean one of these:
Silly question, which way around should this go?
Also another thing, it looks like my breather connector is bent, it's pointing down not forward (see photo of gearbox above). I'm not too keen to trying to bend it back as it might crack. What this means though is that there will be a bend in the hose and some oil may sit there, will this be a problem?
That filter is a little motorbikey one. It'll probably work, but the cheap $2 ones (that look like the original Ryco ones, about 65mm long, maybe 50mm diameter) are probably better. They have more volume inside.
Fit it so that the outside is connected down to the gearbox. The inside of the filter element should face atmosphere.
Use low pressure fuel hose for best resistance to oils.
  • Like 1
    • Assuming the current ECU is stock, it might be worth getting hold of a nissan data scan cable. It could be as simple as voltage at the ECU
    • You need to test for spark when it matters - ie cranking. Kill the fuel supply, pull a plug and earth it, set up a camera and go crank. The spark needs to be consistent, every other turn of the engine. Not some sputtering of occasional spark. The reason I say this is because spinning the CAS in the air is not the same as spinning it installed, and if there is a bearing problem in it, the disk might work differently in the air than in the engine. You won't want to try to set the timing unless you know the spark is happening right.  Also, reconsider running the R35 coils against the stock ECU. They like a different amount of dwell cf the originals. It's not massive, you can actually run them, but it is better if you can adjust the dwell (which you can with Nistune in the stocker, or with an aftermarket ECU). Besides any of that - when you had the multimeter out, have you got power where it needs to be, earth where it needs to be (and when, in the case of igniter triggers), etc?
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
