I think he is the most talented in modern F1, the only person to ever stop Schumacher.
Not entirely accurate. Also go and have a look at the circumstances for the 2005 season and let me know how many GP wins Bridgestone had that year.
In 2006 you could pretty much say that Schuey's untimely engine failure in Japan cost him the WDC
  • Replies 2.5k
Posted Images
Well he said it himself, and his antics at monaco show just how rattled he was.
Alonso had driveshaft failure in 06 that at the time made it almost impossible to win the season too. Or the penalty for 'obstructing' massa that was total bs.
Is there any weather forecasts for race day?
I hope it doesnt rain, we need to see the race pace of everyone minus the weather.
Has anyone ever got pit lane access in melb?
Not sure if its been posted before.. http://www.f1complete.com/content/view/11721/510/
Edited by knore
have some mates who work for supercheap team so can get into v8 paddock but f1 is off limits.
I remember looking up ticket prices awhile back for Melb and there was an all access thing for $3500, it included pit lane and even a special section above the pits to watch the race i think.
Would be worth it if you had the money and werent going by yourself!
saw the GT-R safety car last week at the clipsal 500 on tv
It looks pretty sexi, I hope the safety car driver decides to fang it around the track and take on the v8's that would be funny
Can't wait till the weekend, going to be exciting just how many cars make the finish with kers and the times they post.
We'll see if any teams protest and dont enter the race due to diffuser fisaco
Think mclaren might be hiding their true pace hhmmmm..............interesting
Edited by JUN`R32
what's the go with the diffusers? I read that Brawn, Williams and Toyota have somthing differnt about theirs, but not what it is that is different.
I'll be in Melb to watch it :down:
http://www.pitpass.com/fes_php/pitpass_new...es_art_id=37262
Well I'm at superlap so I miss out on F1 but I got a taste for it today at Kinglake.
I'm up here for work and a BMW and minardi 2 seater ripped some skids and flick turns in the main part of Kinglake as an event for the locals. Frieken loud. Good to see!
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
