  • Replies 2.5k
Posted Images
Massa will be fueled right up this time perhaps with a few kg's extra (just in case) and he is a good chance of cooking his rear tyres so the closing laps for him should be fun.
Turns out he had enough fuel to finish without conserving last race....It was the data that was wrong, but obviously they didn't know the car had enough fuel until after the race when they checked it
really, is that right? ouch for ferrari
i thought his car stopped on the cool down lap. i was overseas and it took me a while to find a tv to watch the race and my italian is a bit sketchy.
I'm only going by what Massa told reporters in the pre qualifying interviews
Save for any mad acco that sees him out for some races, I can't see Button losing the WDC this year, and after only 6 rounds :)
Can't see the team losing the constructors title either, really.
The Brawn GP procession is getting a bit tedious though...
Why RBR didn't pit Vettel earlier when the SS tyres had expired has got me f'ed....
He certainly burnt his rear soft tyres up quicker than anyone else during the race! But he didn't really have any pace even in the first few laps before they would have gone off. I don't think he got his setup anywhere near right.
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
