General Meeting - Tuesday 20 January
  • Replies 56
UPDATE
Seeing as there will not be much to go over at this meeting and the weather looks to be pleasent, we will be running a mini cruise.
Meeting starts at 8pm and we will depart once the formalities of the evening are done.
Plan is to head out Williamstown way - bring your cameras along as there might be some good photo opportunities.
sweet, going towards my side for once.
2nd UPDATE
on top of the little mini cruise weve organised, and now that i have just picked up 2 rather large boxes, i can confirm.......
CALENDARS WILL BE AVAILABLE FOR COLLECTION 2MOZ NIGHT
Thats right - if your a current SAU-Vic member, get yourself down to Bell's 2moz night and get yourself the 2009 Skylines Australia Victoria Calendar for FREE.
I will try to be there between 6 - 6.30.
Anyone who is able, it would be great if you could drop in and pick up your copy of the 09 Calendar.
Tell others :D
Huge thanks to Chris for getting it all done <insertgolfclaphere>
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
