Hi Guys,
I'll be getting my RB25/30 conversion done soon, and I just wanted to confirm with you fellas some prices my mechanic quoted me for.
RB30 bottom end with Forged pistons (I forgot what brand, I'll get back to you on this one) with forged rods, all fitted and machined ready to be bolted on the head of the RB25 - $8,700
GT35R 0.82 A/R housing, 38mm external gate, with the manifold to fit thr RB30 and oil lines from GCG for $3,700
$1,300 for plazmaman plenum
$600 for contruction of new dump pipe and some cooler piping
mechanic estimated around $2,000 for labor to fit everything and tune it.
Do these prices sound about right to you guys? All up that around $16,300.
I already have the cams, injectors, fuel pump, PFC, exhaust, front mount etc etc.
Correct me if I am wrong, but isn't $8,700 for a fully forged RB30 engine a little too expensive?
yeah thats sounds pretty exspensive. $8,700
a great set of pistons should be under $1500, rods well under $1500... i'm guessing stock crank just polished or something, ACL race series bearings, mmm not % sure what they are worth to fill out a RB30. guessing a few hundred. machining costs.... and oil + water pump gasket kit..arp stud kit maybe?
mate unless you are getting the best of the bloody best thats sound rather dear.
you'd wanna be getting some high end pistons rods, rings and bearings and a high end oil & water pump.
only thing is you say "all fitted and machined ready to be bolted on the head of the RB25"
is this including the head work or is that just "ready" for you to bolt a stock 25 head on??
i'd probably go a stock internal'd rips long motor for $4300 AUD but make sure it had oil restrictors and custom drain first (haven't really looked much yet)
as well as the baffeled sump option
Sack the idea of using a GCG manifold. Buy something else. I recommend a steampipe deal from ETM (Extreme Turbo Manifolds). He makes tonnes of them to suit RB30DET's and knows exactly where things need to go on a 33 gtst to keep it all under the bonnet. Truly worth the dollars spent (and it doesn't sound like it would be that much extra judging by the dollars you've quoted.
Link is in my sig.
$3700 for a turbo kit seems pretty extreme..
My turbo setup (going on very soon) cost me:
GT35R 0.82ex - $1600 (new but not from a store, at the time the turbo new from MTQ was ~$1850)
TiAl 44mm gate - $420
High mount manifold - $150 (came off a mates car, not as quality as a 6boost or ETM but makes the numbers)
Oil/Water lines - Will be getting Enzed guy out, am anticpating ~$200
I guess if the exhaust manifold included is a 6boost or ETM item then it's not too bad, if it's a china manifold then you're getting ripped off :P
Ok, so for the $3,700 from GCG, you get the following:
GT3540 0.82 A/R
TiAL 38mm gate
High mount Xtr manifold (Xtr is GCG's in house brand)
Oil and Water lines
Exhaust flange for turbo
Gaskets and nuts.
Do you fellas think this price is reasonable?
Also, will a 38mm gate be large enough for my application (RB25/30 with the GT35R 0.82) or would I require a 44mm gate?
Cheers
i think my high mount ETM was around the $1550, including the water and oil feed and return lines made by ETM and it was also ceramic coated, as was the exhaust housing.
looking at your pricing about $2200 for turbo and gate and $1500 for the rest.
i know what i would pick any day of the week
and i would also recomend 44mm gate as a minimum bigger the better really.
GT3540 0.82 A/R
TiAL 38mm gate
Oil and Water lines
Gaskets and nuts.
Cheers
I've highlighted the bits I'd have an issue with. Also, in-house is very much the wrong word to use. They're the same as the better constructed China manifolds you can buy from ebay. They're not worth the money they charge and they don't work nearly as well as an ETM or 6boost manifold in terms of spool, wastegate flow, collector design, quality etc etc etc...
My best (and last) advice on the subject is to contact Leigh - [email protected] / +61 2 42628774 and ask for:
- High mount manifold to suit a GT35R/RB25/30/ECR33
- 44/45mm Turbosmart wastegate
- Oil and water line kit
Good luck mate.
All the best,
Adrian
Sizing of gate kind of depends on the boost you're going to run.. there's a big thread round here someone on the subject.
I believe it goes along the lines of (roughly), the less boost you want to run the bigger the gate you need (as you will need to bypass more exhaust gas from the turbine).
Short motor does seem a bit excessive..
As far as turbo set-up goes.
Mine all brand new
GT3540 1.06 A/R = $1500
6 boost manifold = $1000
Tial 44mm gate = $450
Edited by Tomek
How much power are you after? Do you really need forgies?
I would personally buy the RIPS standard RB30 for AU$3300 or spend $4300 with the head. They can probably beef it up a little if you want and will cost u a lot less than your quoted $8000+
I am aiming for 370 + rwkw.
So forgies are a must.
    • Fair enough, I am in no way a tire expert so I'm not familiar with all the terms and conditions. I'll definitely note down the AD09 to potentially try in the future. Rain is not too big of a concern for now as I will probably only drive in the rain when I have to. And considering I still lack experience driving the GTR I'd more than likely take it easy too. I have coilovers in the car but as I barely got to drive so far I never bothered to even check if they are adjustable haha. The suspension is almost entirely old and worn as well so I suppose when I eventually fix that in the future that would make a huge difference.
    • There's not a great deal to report here .... except ...... FOR .... LSD!!!  I bought a Quaife LSD from the UK and shipped it here .... Wish I'd just bought locally cause the shipping and duty was $700! But there were so many diffs used in the E90s I just wanted to be absolutely certain I was getting the right one so I spoke with a supplier in the UK who builds race cars and they have heaps of experience with the E90s.  I pulled the diff out which was seriously awesome - I've never done anything like that before, I must have watched 1000 videos on YT about it as well as consulting the Bentley manual. It was super easy in the end. The diff was delivered to the awesome folks at Hornsby Diffs and will be back in a few weeks. I also replaced the diff bushings with some Nolathane ones.  Really looking forward to getting it back and getting back to the track or even the skidpan.
    • yeah... the 13kg/mm springs weren't always in there, I had 10kg/mm but doing a few SMSP commanded heavier front springs. It's so good now going into T1 and T2, just need more seat time and real tyres.
    • Yes, well. Mine are less than half that. ARBs are not set to "dumb" either.
    • I would hope. But, we all know even the best companies have an issue sporadically.
