http://www.anfittingsdirect.com/index.php?...1b11a2817fc507d
Whoever's fuel system that is in the picture- You have to be very carefull putting hose clamps on pushlock hose/fittings.... it will cut the inside if the hose and lift the hose off the barbs either side of the clamp.... it's more likely to leak putting the hose clamp on!
It's not cheap, but aeroquip starlight hose and fittings have been designed for all sorts of ethanol/race fuels... awsome stuff!
Cheers
Justin
The silly old man did the clamps on the hose thing. I have already removed them and will shove them up his ass at the earlieast opportunity.
just what i was gonna say, bosch do them @ 12v not 14
also you other blokes like marko, you sure you are not getting confused with 040 & 044?
sometimes people do that :P
"Each Bosch 044 inline fuel pump provides 300LPH of flow and operate at 72.5 PSI"
...straight off this website: http://www.boschfuelpumps.com/
thats a company website trying to sell pumps... they have written that information themselves, and it contradicts the numbers provided by bosch on their website (www.bosch.com.au)
They look stainless..... they're gonna hurt- sharp edges and all! ha ha ha
http://www.bosch.com.au/content/language1/...s/fuelpumps.pdf
On the bosch website.....but yes as stated above at 12v
I would expect around 220 (maaaaaybe 240Lph) at 14V
Sounds about right, assuming that flow/voltage are fairly directly proportional you are looking at 245l/hr at 5bar.
I would say most street cars are running about 1.5bar plus 3bar base so would push flow up to 260l/hr... So enough to feed 720cc injectors :P
u are right just had a look - shouldnt always believe what i read :P
Even if it were true marko i would still take the pierburg on noise factor alone. You can hardly hear these things, unlike the swarm of hornets unleashed every time you turn the bosch on.
i luv that sound, like having squealing race brakes or BIG cams :P
My 044 mounted in the tank only ever makes an audible sound when priming...otherwise you can hardly hear it while the car's running
your ecu will have the factory fuel pump controler enabled, so below ~1500rpm the fuel pump voltage/current drops to keep noise down, turn it off and you will be able to hear it again.
You're starting to sound like an old man
"Turn that down you young hooligans"
lol
Thats right, when i had one 044 intank you could hear it but it wasnt as bad as people make it out to be...
...the 2 hanging under the car are a different story
lol
Sound like one? He frickin is one!
Oh and I forgot to mention the Pierburg pumps are a pull/push pump so no prime pump required if you don't need a surge tank
Ah internet sarcasm strikes again lol
The old man stole my seat at superlap and i didnt have the guts to tell off a pensioner :)
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
