http://www.anfittingsdirect.com/index.php?...1b11a2817fc507d
Whoever's fuel system that is in the picture- You have to be very carefull putting hose clamps on pushlock hose/fittings.... it will cut the inside if the hose and lift the hose off the barbs either side of the clamp.... it's more likely to leak putting the hose clamp on!
It's not cheap, but aeroquip starlight hose and fittings have been designed for all sorts of ethanol/race fuels... awsome stuff!
Cheers
Justin
The silly old man did the clamps on the hose thing. I have already removed them and will shove them up his ass at the earlieast opportunity.
just what i was gonna say, bosch do them @ 12v not 14
also you other blokes like marko, you sure you are not getting confused with 040 & 044?
sometimes people do that :P
"Each Bosch 044 inline fuel pump provides 300LPH of flow and operate at 72.5 PSI"
...straight off this website: http://www.boschfuelpumps.com/
thats a company website trying to sell pumps... they have written that information themselves, and it contradicts the numbers provided by bosch on their website (www.bosch.com.au)
They look stainless..... they're gonna hurt- sharp edges and all! ha ha ha
http://www.bosch.com.au/content/language1/...s/fuelpumps.pdf
On the bosch website.....but yes as stated above at 12v
I would expect around 220 (maaaaaybe 240Lph) at 14V
Sounds about right, assuming that flow/voltage are fairly directly proportional you are looking at 245l/hr at 5bar.
I would say most street cars are running about 1.5bar plus 3bar base so would push flow up to 260l/hr... So enough to feed 720cc injectors :P
u are right just had a look - shouldnt always believe what i read :P
Even if it were true marko i would still take the pierburg on noise factor alone. You can hardly hear these things, unlike the swarm of hornets unleashed every time you turn the bosch on.
i luv that sound, like having squealing race brakes or BIG cams :P
My 044 mounted in the tank only ever makes an audible sound when priming...otherwise you can hardly hear it while the car's running
your ecu will have the factory fuel pump controler enabled, so below ~1500rpm the fuel pump voltage/current drops to keep noise down, turn it off and you will be able to hear it again.
You're starting to sound like an old man
"Turn that down you young hooligans"
lol
Thats right, when i had one 044 intank you could hear it but it wasnt as bad as people make it out to be...
...the 2 hanging under the car are a different story
lol
Sound like one? He frickin is one!
Oh and I forgot to mention the Pierburg pumps are a pull/push pump so no prime pump required if you don't need a surge tank
Ah internet sarcasm strikes again lol
The old man stole my seat at superlap and i didnt have the guts to tell off a pensioner :)
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List: 1.Anna S 2. Luke S 3. Jesse Givens-Lamb 4. Luca Stamatescu 5. Madeleine Stamatescu
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
