Well it seems that we are on similiar paths for our race cars then. Our goal is to eventually get to the 550rwhp mark with our gt35r though we already run the 1.06 rear. That amount of hp in a rear wheel drive car is around the most you could really actually use. Unless you can get some super trick suspension setups to help get that power to the ground. Just gotta find the right balance for all of it.
I wouldnt be suprised if a split pulse setup actually helps the response abit more then what it is atm. By alot of comparisons that seems to be the case and in theory it makes sense.
I drove it home and back to work again this morning. My only comment on the matter will be :)
As for smell Nismoid - smells like lollipops every time you put your foot down and after sitting over night it smells like sugar cane mulch but much less pungent in the cabin.
I left lollipops all down the highway in 4th
I drove it home and back to work again this morning. My only comment on the matter will be :no:
lol E85, feeds both power and sugar addictions at once :D
Theres a fair bit of buzz around some new borg warner turbo's due to hit the market soon, ti exh wheels, billet comp wheels, dual bb etc. I'm told the 8374 will be a sweet match to the rb26 for us 35r converts.
The only currently available line that can be used 100% with E85 is the Teflon braid 200 series stuff. However the cost to get all the fittings crimped is astronomical so we went with what the sprint car guys are running and it's the blue Goodyear pusklock hose. It's not impervious but we will be changing it out each year. At $15 a meter it doesn't brake the budget.
(Which is extra good for someone like Noel)
Why would you use crimp fittings with the teflon hose when there are screw together fittings designed for the job?
Because no one we buy from knew anything about them and the teflon braid was a lot more expensive. Purely a $ decision
The car smells like North qld at harvest time. The power delivery is just brutal. 1st 2nd and third may as well not exist. 4th is squirrelly as all fark and 5th just holds on. Time for some new semi's.
And it aint over yet. More tuning this arvo.
LOL
*can't get any power down... Lets try and make some more
:no:
Edited by SimonR32
does it have semi's at the moment or just standardish street rubber? much camber on the rear? subframe bushes? stiff springs/shocks?
if you wanted to save the expense of the twin scroll setup, a water meth injection kit with some nitromethane addative will get you that last 20kw for a lot less $$
3rd gear powerskids FTW!
Get up it Noel :ermm:
Noel is officially part of the 400kw club.
Just pulled a 547.5hp run. don't know if they're finished yet....I had to get back to finish putting some engines together.
The setup I drove home on last night hadn't had the EGT's done yet so this morning we installed them and sent it back. Temps were at 600deg so Sean decided to give it some more. Same boost as well.
Drag's tomorrow so fingers crossed my baby holds together like the rest of them.
I'm sure Noel will post final results when they are done but he's had a pretty long day so if he doesn't then I will
pulled up at 555 hp, I now officially belong in this thread,
Cams havnt been touched yet and still shitloads more but enough is enough. I am happy.
Huge thanks to Dan of ERD fame for his herculian effort to get the fuel setup operational in time and to Sean of EFI for more of his magic.
Will post up a pic of the graph later this evening.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
