Hi there, got my car tuned today at Pits on the gold coast.
Mods as follows.
R32 GTR
RB26 bored, decked, cleaned, balanced and the crank ground.
Ross pistons, total seal rings, Spool Conrods.
Head is mildly ported, re-seated etc etc, Tomei 270 dur 10.8 lift cams, Brian Crower springs.
N1 oil pump, tomei oil restrictor.
1200cc injectors, 2 x 044 pumps, 3L surge tank.
Haltech E11v2
STD coils at this stage
115mm intercooler, chinese one i'd say, $400
70mm Billet turbo by Mark at Mr Turbo, Gold Coast
60mm wastegate, ebay cheapie.
4 inch exhaust all the way with 1 straight thru muffler.
twin plate OS clutch.
Tuned today on E85 from the pump, made 564 Hp on 26 psi, 528 hp on 23psi, and 501 on 20psi.:cheers:
Maxed out the injectors at 26 psi, looking at ID 2000's for the next tune. hopefully crack 600 which I don't think will be a problem.
Mods as follows.
R32 GTR
Haltech E11v2
that thing is a light switch... must be fun though
a ute with 400rwkw... umm better buy shares in a tyre company!... might want to invest in Bonds as well... free lifetime supply of underwear
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
